Cold air and pod filters.
- barquirt
16 May 2007 09:28
Does extremely cool or cold air mess up an engine equipped with pod filters? Say, if you're heading out in low 40s or high 30s? My '77 KZ650 has pods on it and I'm wondering if riding when it's that cold might have some kind of bad effect on my engine/jetting... just curious.
- RonKZ650
Re: Cold air and pod filters.
16 May 2007 10:07
I don't think temperature is a problem, but rain and crosswinds are the main headaches you'll see running pods, and the weight of the carbs on the intake manifold rubber takes its toll. Find a way to support the carbs in the rear.
- Wirewulf
16 May 2007 10:24
Can't think of any harm to the engine done by air in that temperature range, in fact mine seems to like the cooler air. But then, high 30s low 40s is too cold for the pilot!:pinch: Be interesting to hear from some cold climate members and some of these guys that ride in the snow. The main thing I'd be concerned about is condensation.
- barquirt
16 May 2007 10:31
I've made some simple support straps for the carbs so they aren't just hanging on the manifold boots. I'd recommend this as it helps for smoother running, too.
Why would crosswinds mess up a set of pods? I could see how a soaking rain might (ha ha, WOULD) be an issue but wind?
- JR
16 May 2007 10:54
barquirt wrote:
No problem at all. Cold air is denser/heavier so the bike seems to run better. I have pods.
No problems with condensation and as for snow - that's what snowmobiles are for
....wish I had one.
- RonKZ650
16 May 2007 11:32
barquirt wrote:
Wind just messes up the flow of air into the pods for lack of a better way to put it. (Or lack of knowing the exact answer).
- wireman
18 May 2007 10:22
barquirt wrote:
blows the air away from the pods making a temporary rich conditionI've made some simple support straps for the carbs so they aren't just hanging on the manifold boots. I'd recommend this as it helps for smoother running, too.
- hwms
18 May 2007 14:08
It is my opinion that given a certain amount of cross flow of air at some velocity at right angles to the pod would result in a somewhat low pressure area thereby causing some reduction in and reversal of the vacumn needed to pull air into the carburater intake.
- wireman
18 May 2007 17:54
hwms wrote:
yeah like harry said!It is my opinion that given a certain amount of cross flow of air at some velocity at right angles to the pod would result in a somewhat low pressure area thereby causing some reduction in and reversal of the vacumn needed to pull air into the carburater intake.
- rstnick
19 May 2007 10:13
My bike would bog down for a moment at times with strong cross winds, when I had pods.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- Sandy
- Fly High,Tony
20 May 2007 10:46
Rode yesterday...it rained a bit,off and on...pretty windy at times,and I noticed a difference in how the bike ran.More popping than usual,and some hesitation at times.
(I'm running pods,btw.)
1977 KZ1000 A-1
