Carb Q's
- vach
Carb Q's
14 May 2007 10:03
What is the little brass tube sticking out of the bottom of the carb? Can I remove those to clean them? 2 of them are completely clogged.. Carb cleaner and air pressure is not working.. Can I pull them out or are they fixed in there?
1979 kz650 B. Chicago, Illinois
- RonKZ650
Re: Carb Q's
14 May 2007 10:14
They are part of the choke system. If they are clogged the choke won't work correctly. I've never tried to remove them.
- Duck
- e vica na i sau na ga
Re: Carb Q's
14 May 2007 12:04
Clean with a piece of wire. Guitar and bicycle control cable are some sources of stiff skinny wire.
-Duck
-Duck
- The Fish
Re: Carb Q's
14 May 2007 15:06
They can be removed, but you have to be careful of breaking them (they have a crossdrilled hole in the top)
Grab it with a pair of ignition pliers (tiny pliers) and rotate it in the hole (gently), and it should work its way out.
GENTLY....
Fish
GENTLY....
Fish
- KaZooCruiser
Re: Carb Q's
14 May 2007 16:25
How did you get the carb on the left so clean, vach?
I'm with Duck, I would try a .10 guitar string before attempting to pull the tube.
Even if I was going to remove it, I would want something inside it to keep it from crushing.
- vach
Re: Carb Q's
14 May 2007 16:55
Cool, got it with a guitar string. Here's a link to the carb cleaning process. I used lemon juice and vinegar. However the vinegar works best alone with water. When you use a dremmil to buff it, it actually came out a bit better.
link to carbs
The finished product.
Post edited by: vach, at: 2007/05/14 19:56
link to carbs
- KaZooCruiser
Re: Carb Q's
16 May 2007 10:57
Kevin,
Thanks for the link and follow up. I am glad you got the passage cleared with a guitar string. I had indicated .10. It should have been .010. . .like an "E" string. 10 thousands, not 100!
As for the vinegar, do you recommend balsamaic, or cider, or what did you use?
White vinegar is acetic acid I think, diluted to 5%.
Is your number three carb in your picture the vinegar only unit?
