Choke Lever
- gaillarry
Choke Lever
12 May 2007 16:12
Just bought an 81 KZ750 LTD with only 9,000 kms, in mint shape. The bike runs ok but on startup the choke lever has me confused. (Mikuni carbs)
When I put the choke lever on (up position) the bike stalls out, if I put the lever off (down position) it runs ok. Is this normal?
1977 KZ1000
1985 Gpz750
1985 Gpz750
- Sandy
- Fly High,Tony
Re: Choke Lever
12 May 2007 16:44
100% normal.
Only use the choke(lift up on the lever) when the bike is cold(first start)...however...some need the choke more than others,so You might have to use it,even when it's warm.
Eventually,You'll learn when to use it,and when to turn it off.
What EVER You do...do NOT leave the bike running with the choke ON,and walk away from the bike...the rpm's will climb,and You'll come back to a bike that's revving at 4k!
That has happened to a few Guys here(I remember reading about it)
Once You start riding(couple blocks),You SHOULD be able to turn the choke off,but like I said...You'll figure it out,just play with it,and Your bike will let You know the rest.
Oh and...WELCOME!:lol:
Post edited by: Sandy, at: 2007/05/12 19:45
1977 KZ1000 A-1
