vm 28 setting
- brianrae33
vm 28 setting
10 May 2007 17:54
running 28's on my 1075..currently has 122.5 mains and stock pilots..great out of the hole..but around 6-7000 rpm has a bit of a stutter..if cracked open she screams..carbs are completely rebuilt, and spottless..this is either a jetting issue or coil mod time..doesn't stutter bad but it is there..any opinions??
1982 kz1000ltd
- tjettim
Re: vm 28 setting
11 May 2007 06:26
Do you mean it stutters at a steady
throttle 7000 rpm? If so raise the needles
one notch.If wfo at 6-7k a stutter comes
in I would go up on the mains.
