need to know float settings for 82 kawasaki 550, please help!
  • dcshortwave
  • dcshortwave's Avatar Topic Author
09 May 2007 07:51
#138508
Howdy. I'm rebuilding the carburetor on my 82 kawasaki 550 A3, but need to know the float settings to finish it up... Can anyone help me out? I sure would appreciate the info before it gets too hot to ride....
sign me motorcycless chick in texas!
peace.
  • loudhvx
  • loudhvx's Avatar
Re: need to know float settings for 82 kawasaki 550, please help!
09 May 2007 08:09
#138515
You have to check it with a hose on the overflow tube. It's the most accurate method. The manual should explain it.
home.comcast.net/~loudgpz/KZ5mnl.pdf
Page 159 of the book is page 169 of the pdf file
Post edited by: loudhvx, at: 2007/05/09 11:15
  • dcshortwave
09 May 2007 08:59
#138532
holy smokes! thanks so much!!!!
  • pyxen
  • pyxen's Avatar
09 May 2007 11:08
#138564
I'm glad that PDF is making the rounds.. 550 riders have gotta get some kind of break now and then. ;)
84 KZ550-F2 LTD
93 ZR550-B4
  • dcshortwave
09 May 2007 11:11
#138567
no kidding - this bike - as cool as it is - is nickel and diming me to death! peace.
  • loudhvx
  • loudhvx's Avatar
10 May 2007 00:03
#138769
The only problem is that there are a lot of errors in that manual.
Best to consult experienced users when doing valve-shims, timing chain inspection, cam-timing.
I'll try to make corrections when I can, sometime, maybe after the season.
  • pyxen
  • pyxen's Avatar
10 May 2007 04:52
#138795
Are they detail errors, or large process errors?
I guess the details are just as bad - but if I'm using it to pull my heads (as an example), the general process is correct, right?
84 KZ550-F2 LTD
93 ZR550-B4
