diagram of bs series mikunis
  • udder
  • udder's Avatar Topic Author
07 May 2007 17:17
#138016
was wondering if any of yall wise folk might steer me in the direction of an exploded view of the bs series of mikuni carbs. can find all others but mine.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: diagram of bs series mikunis
07 May 2007 18:32
#138030
The KZ1000 police bikes have BS34 carb set and the diagram is at buykawasaki.com
The GS1000 FSM has a mixture flow diagram and explaation as to how the carbs work. It's a BIG manual. You are welcome to download a copy from my server.
edebris.com/~bob/GS1000_MANUAL.pdf
-Duck
  • udder
07 May 2007 18:35
#138031
thanks duck may have let the horse get in front of the cart so to speak though i cant seem to find rebuild kits for them. anyone have a super secret stash or am i off to ebay for some new carbs?
  • Duck
  • Duck's Avatar
07 May 2007 18:41
#138034
If the carbs are in good shape, all you need are the bowl gaskets and only if they get torn up when you take carbs apart to clean. If you need parts, get the jets from Jeff at Z1 and other parts from Kawasaki. Nice thing about the bs34's is that most parts are still available from Kawasaki. Diaphragms are expensive enough that it's cheaper to buy a used set of carbs. If "choke" plunger rubbers are bad, get from Kawasaki dealer.
  • udder
07 May 2007 18:51
#138041
ok thanks. these carbs are what came on my kz and i have trouble with idle speed and fouling plugs so i wanna go through them top to bottom but i was having trouble with parts till u came along thanks.
