Normal throttle response?
  • jack hammer
  • jack hammer's Avatar Topic Author
18 Dec 2005 19:38
#13704
What is normal throttle response? With my 78 650 SR on it's center stand and running, when I twist the throttle slowly, the rpms slowly climb accordingly. When the RPMs reach about 2500 they then jump up rapidly to about 5000 without any further twisting. Is this normal?
  • wireguy
  • wireguy's Avatar
Re: Normal throttle response?
18 Dec 2005 19:41
#13705
is the bike warmed up when you do this?
  • jack hammer
18 Dec 2005 19:48
#13706
Yes the bike is warmed up......
  • The Milkman
  • The Milkman's Avatar
18 Dec 2005 20:46
#13710
Before you go doing much with the carbs. Take the points cover off and check the centifugal advace for binding or looseness. It sounds like it may be binding and releasing suddenly and doing a quick timing advance. With a good light, not a timing light, you can watch it as you slowly rev the engine to see if it's operating smoothly.
  • jack hammer
22 Dec 2005 13:30
#14100
I opened up the points cover and observed the mechanical advaance. It appeared as if it was moving in sinc. with the before mentioned problem. I squirted some wd40 in there and things lossened up to the point of no problem now. Thanks for the advice. It got right to the problem.
  • wiredgeorge
  • wiredgeorge's Avatar
23 Dec 2005 05:58
#14226
A shop manual will explain that you are supposed to remove the mechanical advance and clean the end of the crank and the advance and lube them both periodically else they get sticky... The reason is that both are made out of steel and tend to oxidize. You might want to remove them and clean them up some to get rust off.
