mod problems
- rdgrnr
Re: mod problems
11 May 2007 07:17
wg, thanks for the help.
I checked for the markings on the carbs, but could not find any. The bowl vents tubes are correct as you described. I will check the jug for marking.
Where does the hoses for the emissions go?
Thanks again,
Thanks again,
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- rdgrnr
Re: mod problems
14 May 2007 09:41
ok, block says 1015. Still can't find any markings on the carb flange. I am thinking only mods made to this was the 4-1 Kerker. Carbs look like they have been on there for a long time, so maybe stock set-up. I am going to remove them and have them cleaned and rebuilt.
Should I go one size bigger on the jets for the exhaust set-up?
Thanks
Thanks
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
