77 KZ650 Petcock Options
- bemoore
01 May 2007 10:54
My petcock is leaking. After a bit of a search here I see that I'm in good company. My first stop was Z1 Enterprises, but they don't show a rebuild kit or a replacement petcock for my bike. I'm going to try disassembly and cleaning, but I'm not too optimistic. I found this discussion
kzrider.com/component/option,com_joomlab...id,3/id,23976/#23976
involving a Suzuki vacuum petcock. Is this my best option? Mine is currently manual. Would there be any problems converting to a vacuum type?
77 KZ650C1 w/Kerker 4-1
- rstnick
Re: 77 KZ650 Petcock Options
01 May 2007 11:43
Only problem I can see is where the vacuum line connects to the #2 carb. I don't recall if the port is there, plugged or just capped?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- bemoore
01 May 2007 12:30
The port is there with a cap on it.
- RonKZ650
01 May 2007 13:29
My 1977s have no vacuum port on the #2 carb, but you can run a vacuum line to any of the 4 carburetor sync caps on the intake boots if you have too. This looks good, but what is the advantage of the suzuki petcock vs a Kawasaki? Suzuki less money or more reliable?
- RetroRiceRocketRider
01 May 2007 21:12
RonKZ650 wrote:
Simple.
The Kaw KZ650 petcock (and all 5 of the sub #s for it) is no longer available, and there's not a dealer in the U.S. that shows one in stock on the Kawi parts locator web system - trust me, I checked.
The Suzi petcock is still available, and IIRC is cheaper than what the last price on the OEM petcock was.
FWIW a Kawi Cop bike petcock will also work, which is what I'm running now on my 650.
It was the only (still available) vacuum petcock I could find to fit my bike at the time, and the local dealer just happened to have one in stock.
Simple.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- bemoore
03 May 2007 05:18
RonKZ650 wrote:
Easy.
Suzuki petcock -> available
Kawasaki petcock -> not available, unless I'm mistaken, which is what I was trying to determine with my original question.
My mistake. I thought one of the sync ports was used for the petcock. Mine doesn't have a separate vacuum port either.My 1977s have no vacuum port on the #2 carb, but you can run a vacuum line to any of the 4 carburetor sync caps on the intake boots if you have too. This looks good, but what is the advantage of the suzuki petcock vs a Kawasaki? Suzuki less money or more reliable?
Easy.
- RonKZ650
03 May 2007 19:47
All the vacuum petcocks have been discontinued by Kawasaki? That's a dang good reason to go the Suzuki routt.:ohmy: But, for info Kawasaki made a lot of vacuum petcocks that had the same spacing, such as KZ750, 79-up KZ1000, even GPZ750 up well into the 80s. Some of these must be available. They may have slight variations from the KZ650 such as vacuum port sticking out 90 degree different which can be easily changed, fuel outlet slightly larger diameter, fuel pickup tubes a little different so reserve tank capacity will vary ect. Any of these will work and there must be availabilty on some of them I would hope, but who knows.
