exhaust from new sportbike on a kz 650
- oldkaws4ever
- Have no regrets...... You only live once.
23 Apr 2007 22:39
i have always wondered if you caould adapt a exhaust from a newer crotch rocket on to an older 77 kz 650, of could i adapt a "slip on" muffler from a newer bike
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- rattler
Re: exhaust from new sportbike on a kz 650
24 Apr 2007 01:18
you can but it will take a little work. a few ppl here have done this with there kz's. one way i have seen it done was they use a vance hines or kerker header(collectors only)and have a custom midpipe like the new superbikes use made up so it will slide on to the old school exhaust were the megaphone would normaly mounts to the exhaust. the other end of the midpipe would to be sized to fit the canister you choose to use from a superbike. also you would need to make up a mounting brackets for the exhaust.
- lowbuck
24 Apr 2007 04:37
Try an exhaust from a ZR-7. There is a very recent thread regarding this setup on a KZ700. You'd still need to fab brackets, etc.
- Paling1
24 Apr 2007 05:47
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
- JMKZHI
Last edit: 03 Dec 2008 13:37 by JMKZHI.
