Help!! Fuel line configuration 79' KZ650
- Cableman
22 Apr 2007 18:51
Can anyone help me with my fuel line configuration on my 1979 KZ650? I picked up the bike and it had no fuel lines so I picked up some on ebay, but now I don't know which goes where. I know where the prime is but the other three got me stumped.
If anyone has a picture of theirs that would be extremely helpful.
Thanks
Rick
Thanks
Rick
- kawsakiman
Re: Help!! Fuel line configuration 79' KZ650
22 Apr 2007 19:05
my 80 has only a feed and a vacuum fitting.
are you looking for the petcock positions?
i'm a little confused on your question
- Cableman
22 Apr 2007 19:08
I'm Not sure. There are 4 inlets on the carb and only two outputs on the petcock and I have no clue how to connect the carbs to the tank properly.
- kzwolfsr
22 Apr 2007 19:15
Which carbs do you have, since 79 carbs are diffrent from 1980 carbs so do you have carbs like this? I think Mikuni is what I have. I don't think you have CV's as yet, not in that year
Post edited by: kzwolfsr, at: 2007/04/22 22:27
Original man of the Caribbean
- Cableman
- kawsakiman
22 Apr 2007 19:25
there should only be one fuel feed line.
i think you are looking at the vents for the floats.
go to www,wgcarbs.com and look at his pictures.
he is the man.
might be a good idea to also send him your carbs for a once-over
Post edited by: kawsakiman, at: 2007/04/22 22:32
he is the man.
- Cableman
22 Apr 2007 19:41
If there should only be one feed than why is there two ports on the petcock? and which port on the carb is the feed?
- kawsakiman
22 Apr 2007 19:50
one is the fuel feed, the other four are bowl vents.
pictures of your carbs would be real helpful
i am assuming you have 24's on a 650 but i could be wrong.
the one between two and three should be the feed line.
the one on the bodies should be the the vents
one vent on the petcock is to supply fuel, the other is for vacuum.
the vacuum side is the smaller one.
it shuts off fuel when the bike is not running so if there is a problum, you don't empty your tank because of a stuck float.
- kzwolfsr
22 Apr 2007 20:01
ok I redid your pic a bit
- kzwolfsr
22 Apr 2007 20:02
- kzwolfsr
22 Apr 2007 20:06
atmosphere line on left is if you have 2 ports there, either that or they might be vacuum ports. Fuel t in the center for fuel line
Post edited by: kzwolfsr, at: 2007/04/22 23:09
- Cableman
23 Apr 2007 05:38
That really helps. Thanks. I will put a pic of my carbs up so that I can make sure that every thing is the same.
Thanks
Thanks
