Help!! Fuel line configuration 79' KZ650
  • Cableman
  • Cableman's Avatar Topic Author
22 Apr 2007 18:51
#132876
Can anyone help me with my fuel line configuration on my 1979 KZ650? I picked up the bike and it had no fuel lines so I picked up some on ebay, but now I don't know which goes where. I know where the prime is but the other three got me stumped.
If anyone has a picture of theirs that would be extremely helpful.
Thanks
Rick
  • kawsakiman
  • kawsakiman's Avatar
Re: Help!! Fuel line configuration 79' KZ650
22 Apr 2007 19:05
#132882
my 80 has only a feed and a vacuum fitting.
are you looking for the petcock positions?
i'm a little confused on your question
  • Cableman
22 Apr 2007 19:08
#132884
I'm Not sure. There are 4 inlets on the carb and only two outputs on the petcock and I have no clue how to connect the carbs to the tank properly.
  • kzwolfsr
  • kzwolfsr's Avatar
22 Apr 2007 19:15
#132889
Which carbs do you have, since 79 carbs are diffrent from 1980 carbs so do you have carbs like this? I think Mikuni is what I have. I don't think you have CV's as yet, not in that year
Post edited by: kzwolfsr, at: 2007/04/22 22:27
Original man of the Caribbean
  • Cableman
22 Apr 2007 19:19
#132891
Carbs like what?
  • kawsakiman
22 Apr 2007 19:25
#132893
there should only be one fuel feed line.
i think you are looking at the vents for the floats.
go to www,wgcarbs.com and look at his pictures.
he is the man.
might be a good idea to also send him your carbs for a once-over
Post edited by: kawsakiman, at: 2007/04/22 22:32
  • Cableman
22 Apr 2007 19:41
#132900
If there should only be one feed than why is there two ports on the petcock? and which port on the carb is the feed?
  • kawsakiman
22 Apr 2007 19:50
#132906
one is the fuel feed, the other four are bowl vents.
pictures of your carbs would be real helpful
i am assuming you have 24's on a 650 but i could be wrong.
the one between two and three should be the feed line.
the one on the bodies should be the the vents
one vent on the petcock is to supply fuel, the other is for vacuum.
the vacuum side is the smaller one.
it shuts off fuel when the bike is not running so if there is a problum, you don't empty your tank because of a stuck float.
  • kzwolfsr
  • kzwolfsr's Avatar
22 Apr 2007 20:01
#132911
ok I redid your pic a bit
  • kzwolfsr
  • kzwolfsr's Avatar
22 Apr 2007 20:02
#132912
pic
  • kzwolfsr
  • kzwolfsr's Avatar
22 Apr 2007 20:06
#132915
atmosphere line on left is if you have 2 ports there, either that or they might be vacuum ports. Fuel t in the center for fuel line
Post edited by: kzwolfsr, at: 2007/04/22 23:09
  • Cableman
23 Apr 2007 05:38
#132990
That really helps. Thanks. I will put a pic of my carbs up so that I can make sure that every thing is the same.
Thanks
