airbox hoses
- Booncha57
airbox hoses
18 Apr 2007 18:05
has anybody replaced hard airbox hoses and been surprised at how easily they can remove the carbs now? i either need to replace the tubes i had to cut to get off or buy pods. i would like to replace the hoses but would like to know if it will be much easier to get the carbs in and out if you can bend that rubber or is it just that you dont have room to work with in there?
- kzwolfsr
Re: airbox hoses
18 Apr 2007 18:24
Ive done it. Just get new hoses, and when putting them on I pushed the hoses through the airbox, out onto the carbs. It's easy with new hoses
Original man of the Caribbean
- bill_wilcox100
Re: airbox hoses
18 Apr 2007 19:49
I did it last summer with new carburetor intake hoses and new spring hose clamps.
But, to remove the carburetor I seem to remember that I had to remove the battery box, unscrew the airbox and move the air box as far back as possible. I believe that I had to remove the timing chain tensioner also. Finally, it was possible to wiggle the cab assembly out... not easily but do-able. I had to be really careful because I did no want to scratch up my airbox which I had recently painted with a plastic compatible gloss black spray paint (turned out really nice).
However, kzwolfsr may have found an easier way to do that last step.
Best of success! Keep that 77 KZ650 rolling.
Post edited by: bill_wilcox100, at: 2007/04/18 22:50
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- Booncha57
Re: airbox hoses
18 Apr 2007 20:44
ok guys, thanks a lot. if anybody has any tips that would be helpful go ahead and chime in. right now it looks as though im going to replace the hoses and go the stock route. so if you read this jeff, ill probably be in there on monday to pick them up!
