kz1000 carbs
- chevy502
kz1000 carbs
17 Apr 2007 15:37
i am new to this forum and was just wondering if anyone could tell some good settings to be at with y carbs? I have a 78 1000 with 28mm carbs w/acccel pump right now i have 130 mains with 17.5 pilot jets bike needs to idle at 14-1500 and will stutter and pop when trying to get going from a stop. bike will pull ok when wide open. also when running below 3000 bike will tend to pop sometimes. i have had this bike for a few years and had had it in the shop for this problem before and the dude sold me a new set of carbs and now i am still having the same problem. also the bike has 4 into 1 header muffler and pods.
thanks,
Tom
thanks,
Tom
- Frank
Re: kz1000 carbs
17 Apr 2007 16:54
pods + 4-1 (aftermarket i assume) = needs jetting
your running lean
your running lean
- arobsum
Re: kz1000 carbs
17 Apr 2007 17:09
running lean with 130's? or are you talking about the idle jets? just curious.
- wiredgeorge
Re: kz1000 carbs
17 Apr 2007 18:13
He said his main jets are #130s... He said his pilot jets were #17.5 - The 28 pumpers are not stock on that bike and are overjetted... #120 main jets are plenty big. The popping is most likely ignition related. Could also be lack of valve clearance on one or more valves.
- chevy502
Re: kz1000 carbs
17 Apr 2007 19:06
thanks guys,
George you said im over jetted you think i should go down to a 120? should i leave the 17.5 in as well or go with a 15? i noticed that my pump diaphram is a little stiff so i will be replacing it. also i dont know the age of the intake manifolds so i think i should replace them as well. I love this bike and have gien it to my wife last year and she learned to ride on it and now she really wants it running well, i tusted a shop to do the work for me and got hosed. now its time for a crash course in carbs. I do all other mechanical work myself but always tried to stay away from carbs
- wiredgeorge
Re: kz1000 carbs
18 Apr 2007 05:30
Stay with the #17.5 pilots. Good luck.
- chevy502
