whoops no gas!!
  • faas454
  • faas454's Avatar Topic Author
whoops no gas!!
15 Apr 2007 15:24
#130434
hey guys... ran my 77kz1000 out of gas now its got no power.. it will run but feels like it left its balls on ocean parkway! any suggestions? thanks
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: whoops no gas!!
15 Apr 2007 15:48
#130440
Hmmm...stuck float?
Tap the carbs with the handle of a screwdriver while You turn the gas on,at the petcock.
Make sure the bike isn't on the kickstand though,as with the bike leaning over like that,and if You DO have a stuck float,You'll have a better chance of it freeing itself if the bike is level.
Welcome!!!(by the way)B)
1977 KZ1000 A-1
  • faas454
Re: whoops no gas!!
15 Apr 2007 16:19
#130451
thanks for the tip and the welcome.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: whoops no gas!!
15 Apr 2007 16:28
#130454
Welcome to KZr faas454.
When was the last time you checked the screen and pickup tubes on the fuel tap?
If you ran the tank (and obviously the carbs) completely empty, it's more than likely any gunk/debris/small critters in the tank are now partially clogging that screen or the pickup tubes.
Try this easy test.
With the fuel knob in the OFF position, disconnect the fuel supply line and then turn the knob to the ON position, and then to the RES position.
If no fuel flows out in either position, or barely dribbles out, then your fuel tap is clogged.
Post edited by: RetroRiceRocketRider, at: 2007/04/15 19:32
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
