carb calibration
  • leitrum
  • leitrum's Avatar Topic Author
carb calibration
13 Apr 2007 15:36
#129758
I have the haynes manual, an i can't seem to find anywhere how to calibrate the carbs. Can someone explain how to calibrate the carbs. thx Tim
  • dkmk
  • dkmk's Avatar
Re: carb calibration
13 Apr 2007 18:10
#129802
Tim, look up. Way up. :laugh: Go to the KZ information tab, choose file base, and browse. That's a good starting point, and if you want to get specific, use the search forum box, and manipulate your keywords to find what you are looking for. Don't forget the archives, another wealth of info. If it has been done to a KZ, it is here. Just have to go hunting. Good luck! B)
Post edited by: dkmk, at: 2007/04/13 22:02
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
  • wiredgeorge
  • wiredgeorge's Avatar
14 Apr 2007 08:01
#129977
Not everything is mentioned here... the stuff that is too embarrassing, I keep to myself! Bwhahahaha
Calibrate carbs? Hmmmm Get that Haynes manual out and perform the tune up steps... The carbs will be at the end and will consist of adjusting your throttle cable play and sync and idle speed adjustment. To adjust throttle cables, just make sure they have a bit of visible slack. You do this by turning the adjusters up at the switchtgear. Without slack, the throttle will hang open a tad. To sync, you warm bike up and at idle... put mercury gauges on sync ports and use the sync adjuster located between the two carbs to make the mercury levels the same... and idle speed? The tach is probably inaccurate so set it by ear. Should be below 1500 rpm depending on how inaccurate the tach is... spec is likely more like 1100 rpm but you would need an accurate external tach to set it exactly so just do it by ear.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
14 Apr 2007 09:34 - 20 Feb 2013 18:52
#130015
Last edit: 20 Feb 2013 18:52 by H1Vindicator.
  • H1Vindicator
Re: ----
14 Apr 2007 09:47 - 20 Feb 2013 18:39
#130017
Last edit: 20 Feb 2013 18:39 by H1Vindicator.
