fuel injected 81' kz1000
- acidgypc26
09 Apr 2007 20:13
I have a fuel injected kz1000 and I have none of the peices need for the fuel injection and I have heard that if you cap the injector holes you can run carburetors is this true and what kinda carbs cuase I tried a few sets even one off a 77 kz1000 and no luck none of them match up to the head boots. even tried to see if I can swap manifolds and put different carbs on stock manifolds no go. need help please.....
- kzwolfsr
Re: fuel injected 81' kz1000
09 Apr 2007 20:22
First of all you need to get the carbs from that year bike, since those are a different style and kind of carbs. You need CV carbs. Why are you abandoning the fuel injection anyways?
Original man of the Caribbean
- kzwolfsr
09 Apr 2007 20:26
Forget the last question. You need the carbs and carb holders for that year bike which I happen to have but I dont have extra parts. Check
www.z1enterprises.com
for those parts. You can go through 81 kz1000 k1 model which I have. I don't no much about the other models
- wiredgeorge
10 Apr 2007 05:49
You can use VM style carbs by plugging the holes on your cylinder head that are used for the FI stuff and mounting the correct carb holders. The mount bolt offset will not be the same for the carb holders and you will have to elongate the holes with a dremmel or file. You can use constant velocity carbs; either BS34 Mikuni or CV34 Keihin. Use the correct carb holders as the flange varies on these carbs and use the correct throttle cable. Your OEM airbox should work fine.
