stutter between 5k-6k?
- reborn650
Re: stutter between 5k-6k?
04 Jun 2007 20:53
martijn wrote:
Just to clarify things - Moving the circlip upwards on the jet needle leans out the mixture. Moving the circlip downwards richens the mixture. This can be a bit confusing when using the words clipping up or down.
I tried to post the image that kzr member "gas" used to use in his avatar but I couldn't get the pic to load. Maybe someone else will have better luck converting gas's avatar gif to a jpg and posting it in this thread.
Cheers-Colin Firth
Post edited by: reborn650, at: 2007/06/05 00:00
Maverick wrote:Forgive my ignorance, but I'm just trying to reason through this martijn... So if the clip was too high, then the needle was too low, and lowering the clip would raise the needle and give more gas making a richer mixture. Am I thinking about this backwards? :huh: If you want to lean out the mixture in the mid-range, wouldn't you want to raise the clip, thereby lowering the needle?<br><br>Post edited by: Maverick, at: 2007/06/03 23:25
Oohps:blush:
You are right... I made a mess of it. Yes the clip was on the lowest therfore the needle in the highest position.
I lowered the needle by raising the clip:woohoo:
Thanks Maverick!!
Cheers-Colin Firth
-1998 Jeep TJ Wrangler 4.0...
- Maverick
