stutter between 5k-6k?
- Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- roystaylor
- reborn650
It would be interesting to hear from some of the veteran Kz owners on their opinions.
-1998 Jeep TJ Wrangler 4.0...
- Maverick
- Thank you received: 1
Cheers,
Maverick
1981 KZ1000M1
- Capt. Quirk
- martijn
good luck!
- Maverick
Post edited by: Maverick, at: 2007/06/03 23:25
1981 KZ1000M1
- Capt. Quirk
Are you running Pod Filters? My 81 KZ1000 has pod filters and has a similar stutter, but at a higher RPM. I've heard that this can be caused when you take off the airbox and install pod filters. Supposedly the airbox is engineered to provide the optimum intake air travel length which is shortened when you install the pods. I've also heard that one solution to this is to run velocity stacks, but they have their own drawbacks. Can anybody out there confirm this?
Cheers,
Maverick
I always told customers to keep their stock air box. It had a plenum to draw non turbulent air from, and supply to 4 velocity stacks. Pods end up developing the same problems as air box boots eventually and then everything went to pot when the Dyno Jet kits came out.
- martijn
Forgive my ignorance, but I'm just trying to reason through this martijn... So if the clip was too high, then the needle was too low, and lowering the clip would raise the needle and give more gas making a richer mixture. Am I thinking about this backwards? :huh: If you want to lean out the mixture in the mid-range, wouldn't you want to raise the clip, thereby lowering the needle?<br><br>Post edited by: Maverick, at: 2007/06/03 23:25
Oohps:blush:
You are right... I made a mess of it. Yes the clip was on the lowest therfore the needle in the highest position.
I lowered the needle by raising the clip:woohoo:
Thanks Maverick!!
- oldkaw79
- Maverick
Cheers!
Maverick
1981 KZ1000M1
- reborn650
Oohps:blush:
Thanks Maverick!!
Double post. Please delete.
Post edited by: reborn650, at: 2007/06/05 00:05
