84 750 GPZ Carbs
  • 84gpz750
  • 84gpz750's Avatar Topic Author
84 750 GPZ Carbs
30 Mar 2007 19:08
#125051
new to the motorcycle world,bike will not idle when choke is in and idles way up to about 5000 with choke on,removed carbs and cleaned them,also noticed one of the needle and seats is missing a rubber o'ring,will this cause a vacum leak,it is on one of the outside carbs,any input would be a great help. The bike has dyna coils,accel wires and a kirker pipe,I have the 4 seperate cone style air filters for it.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: 84 750 GPZ Carbs
31 Mar 2007 07:53
#125146
Will allow gas to drool past the float needle/seat assembly and flood the carb. It won't create a vacuum leak as there is no vacuum in the float bowl.
