carb rebuild help
- unkle fester
carb rebuild help
29 Mar 2007 18:52
I am rebuilding my carbs on a 78 kz650b2 using K&L kits and I have a couple of o rings left that I don't know where they go....one is a little bitty teeny one and there are 2 in the kit that fit the bowl drain plug, but I'm sure one goes somewhere else.....ALSO.....like a dumbass, I didn't write down any of the carb settings, so I need a good starting point.....stock air box and filter, 90 jets, clip is 4th from the top (or second from the bottom) Jardine 4 into 2 (will be taking the baffles out).....just need a good baseline to start.....thanks
Re: carb rebuild help
30 Mar 2007 03:02
Probably already studied the exploded view, but hoping another look might be helpful.
and the parts
Ref # Part # Description Qty Spec #
1 16005-027
Add to pick list TOP,MIXING CHAMBER 4 4
1 16005-027
4 16019-031
Add to pick list GASKET,CHAMBER TOP 4 4
4 16019-031
5 16003-013
Add to pick list NUT,5MM 4 4
5 16003-013
6 461F0500
Add to pick list WASHER SPRING 5MM 8 8
6 461F0500
7 16039-016
Add to pick list WASHER,PLAIN 4 4
7 16039-016
8 16046-012
Add to pick list SCREW,SLOTTED 4 4
8 16046-012
9 16057-002
Add to pick list SEAT,SPRING 4 4
9 16057-002
10 16040-026
Add to pick list SPRING 4 4
10 16040-026
11 16067-006
Add to pick list BOLT,HEX HEAD,5X14 4 4
11 16067-006
12 39075-1001
Add to pick list LEVER,THROTTLE 4 4
12 39075-1001
13 16033-031
Add to pick list SCREW,PAN HEAD,3X14 8 8
13 16033-031
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-272)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1020)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1022)
14 16007-028
Add to pick list BRACKET,THROTTLE VALV 4 (for 16001-1069)
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 0 4
14 39184-1001
Add to pick list BRACKET,THROTTLE VALV 4 4
14 39184-1001
15 16008-010
Add to pick list CIRCLIP 4 4
15 16008-010
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-272)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1020)
16 16009-071
Add to pick list JET NEEDLE,5DL3 4 (for 16001-1022)
16 16009-1013
Add to pick list JET NEEDLE,5CN15 4 (for 16001-1069)
16 16009-1015
Add to pick list JET NEEDLE,5CL10 4 (for 16001-1026)
16 16009-1029
Add to pick list JET NEEDLE,5CL16 0 4
16 16009-1029
Add to pick list JET NEEDLE,5CL16 4
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1020)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1022)
17 16025-1006
Add to pick list VALVE,THROTTLE 4 (for 16001-1069)
17 16025-1016
Add to pick list VALVE,THROTTLE,CA2.0 4 (for 16001-1026)
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 0 4
17 16025-1025
Add to pick list VALVE,THROTTLE,CA1.75 4
18 16076-003
18 16076-003
19 16073-014
Add to pick list COLLAR 4 4
19 16073-014
20 16039-015
Add to pick list CAP,STARTER PLUNGER 4 4
20 16039-015
21 16012-015
21 16012-015
22 670B1509
Add to pick list "O" RING,9MM 4 4
22 670B1509
23 16013-008
Add to pick list SPRING,STARTER PLUG 4 4
23 16013-008
24 16016-021
Add to pick list PLUNGER,STARTER 4 4
24 16016-021
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-272)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1020)
25 16017-096
Add to pick list NEEDLE JET,O-8 4 (for 16001-1022)
25 16017-1021
Add to pick list NEEDLE JET,0-4 4 (for 16001-1069)
25 16017-1018
Add to pick list NEEDLE JET,AO-7 4 (for 16001-1026)
25 16017-1034
Add to pick list NEEDLE JET,AO-5 0 4
25 16017-1034
Add to pick list NEEDLE JET,AO-5 4
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-272)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1020)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1022)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1069)
26 16047-005
Add to pick list PIPE,BLEED 4 (for 16001-1026)
26 49122-1006
Add to pick list PIPE,BLEED 0 4
26 49122-1006
27 16038-016
Add to pick list "0" RING,MAIN JET COV 8 8
27 16038-016
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-272)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1020)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1022)
28 92063-1028
Add to pick list MAIN JET,#A102.5 4 (for 16001-1069)
28 92063-1029
Add to pick list MAIN JET,#A90R 4 (for 16001-1026)
28 92063-1035
Add to pick list MAIN JET,#A97.5R 0 4
28 92063-1035
Add to pick list MAIN JET,#A97.5R 4
28 92063-1033
Add to pick list MAIN JET,#A100 4 4
28 92063-1033
28 92063-1042
Add to pick list MAIN JET,#A105R 4 4
28 92063-1042
28 92063-073
Add to pick list JET-MAIN NO 107.5R 4 4
28 92063-073
28 92063-068
Add to pick list MAIN JET NO 92.5R 4 4
28 92063-068
28 92063-1031
Add to pick list MAIN JET,#A95 4 4
28 92063-1031
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-272)
29 16022-016
Add to pick list SPRING,PILOT SCREW 4 (for 16001-1026)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-272)
30 16014-018
Add to pick list SCREW,PILOT ADJUSTING 4 (for 16001-1026)
31 16038-024
Add to pick list "O" RING 4 (for 16001-272)
31 16038-024
Add to pick list "O" RING 4 (for 16001-1026)
32 16012-022
Add to pick list CAP,LIMTTER 4 (for 16001-1026)
32 11012-1041
Add to pick list CAP,LIMITER 4 (for 16001-1026)
33 16029-004
Add to pick list WASHER FLOAT VLV SEAT 4 4
33 16029-004
34 16030-1001
Add to pick list FLOAT VALVE ASSY 4 4
34 16030-1001
35 92064-1018
Add to pick list PILOT JET,#A15 4 4
35 92064-1018
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-272)
36 92064-1019
Add to pick list PILOT JET,#A50 4 (for 16001-1026)
37 16031-031
Add to pick list FLOAT 4 4
37 16031-031
38 16032-003
Add to pick list FLOAT PIN 4 4
38 16032-003
39 11009-1563
Add to pick list GASKET,FLOAT CHAMBER 4 4
39 11009-1563
41 16049-007
Add to pick list SCREW,GUIDE 4 4
41 16049-007
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 0 4
42 16014-1004
Add to pick list SCREW,PILOT ADJUSTING 4 4
42 16014-1004
42 16014-1004
42 16014-1006
Add to pick list SCREW,AIR ADJUSTING 4 (for 16001-1069)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1020)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1022)
43 16038-022
Add to pick list "O" RING 4 (for 16001-1069)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1020)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1022)
44 16022-007
Add to pick list SPRING-THR STOP SCREW 4 (for 16001-1069)
45 13169-1107
Add to pick list PLATE,JET NEEDLE 0 4
45 13169-1107
Add to pick list PLATE,JET NEEDLE 4 4
45 13169-1107
46 92027-1103
Add to pick list RING,JET NEEDLE 0 4
46 92027-1103
Add to pick list RING,JET NEEDLE 4 4
46 92027-1103
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 0 4
47 92022-1024
Add to pick list WASHER,THROTTLE VALVE 4 4
47 92022-1024
48 92081-1072
Add to pick list SPRING,JET NEEDLE 0 4
48 92081-1072
Add to pick list SPRING,JET NEEDLE 4 4
48 92081-1072
Post edited by: Patton, at: 2007/03/30 06:06
and the parts
1 16005-027
1 16005-027
4 16019-031
4 16019-031
5 16003-013
5 16003-013
6 461F0500
6 461F0500
7 16039-016
7 16039-016
8 16046-012
8 16046-012
9 16057-002
9 16057-002
10 16040-026
10 16040-026
11 16067-006
11 16067-006
12 39075-1001
12 39075-1001
13 16033-031
13 16033-031
14 16007-028
14 16007-028
14 16007-028
14 16007-028
14 39184-1001
14 39184-1001
14 39184-1001
15 16008-010
15 16008-010
16 16009-071
16 16009-071
16 16009-071
16 16009-1013
16 16009-1015
16 16009-1029
16 16009-1029
17 16025-1006
17 16025-1006
17 16025-1006
17 16025-1016
17 16025-1025
17 16025-1025
18 16076-003
18 16076-003
19 16073-014
19 16073-014
20 16039-015
20 16039-015
21 16012-015
21 16012-015
22 670B1509
22 670B1509
23 16013-008
23 16013-008
24 16016-021
24 16016-021
25 16017-096
25 16017-096
25 16017-096
25 16017-1021
25 16017-1018
25 16017-1034
25 16017-1034
26 16047-005
26 16047-005
26 16047-005
26 16047-005
26 16047-005
26 49122-1006
26 49122-1006
27 16038-016
27 16038-016
28 92063-1028
28 92063-1028
28 92063-1028
28 92063-1028
28 92063-1029
28 92063-1035
28 92063-1035
28 92063-1033
28 92063-1033
28 92063-1042
28 92063-1042
28 92063-073
28 92063-073
28 92063-068
28 92063-068
28 92063-1031
28 92063-1031
29 16022-016
29 16022-016
30 16014-018
30 16014-018
31 16038-024
31 16038-024
32 16012-022
32 11012-1041
33 16029-004
33 16029-004
34 16030-1001
34 16030-1001
35 92064-1018
35 92064-1018
36 92064-1019
36 92064-1019
37 16031-031
37 16031-031
38 16032-003
38 16032-003
39 11009-1563
39 11009-1563
41 16049-007
41 16049-007
42 16014-1004
42 16014-1004
42 16014-1004
42 16014-1004
42 16014-1006
43 16038-022
43 16038-022
43 16038-022
44 16022-007
44 16022-007
44 16022-007
45 13169-1107
45 13169-1107
45 13169-1107
46 92027-1103
46 92027-1103
46 92027-1103
47 92022-1024
47 92022-1024
47 92022-1024
48 92081-1072
48 92081-1072
48 92081-1072
- inline79
01 Apr 2007 09:54
Hey, I just rebuilt a B2 and C2 carb this winter.
The two o-rings that can be replaced are the one on the drain screw and the one around the main jet holder. I'm looking at my leftovers and see that I still have an extra o-ring left.
The stock main jet for the B2/C2 is 102.5, needle at the 4th clip position, and air screws 1 1/2 turns out from lightly seated. This is assuming you actually have B2 carbs on your B2, and they use the shorter of the two air screws (the third is a pilot screw) in the kit.
I've got another thread where I talk about how my K&L pilot jets were messed up and probably a bit smallish, causing rough running on cold starts.
