29mm SmoothBore float adjustment ?
- jtmcculloch
25 Mar 2007 16:02
I need to know the float adjustment procedure for the 29mm SmoothBore carbs.
I would think that the adjustment is measured from the bowl gasket to the bottom of the float. Is this correct? and if so what is the measurement?
Post edited by: jtmcculloch, at: 2007/03/25 19:03
Post edited by: jtmcculloch, at: 2007/03/25 20:31
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
- wiredgeorge
Re: 29mm SmoothBore float adjustment ?
27 Mar 2007 12:45
As you say, the measurement must be made with carbs upside down, measuring from the gasket mating surface (gasket removed) to the top of the float. They should be 23mm. Only bend the tang that touches the float needle. Bending the float itself renders the adjustment meaningless as the float is then out of whack.
- tw..
28 Mar 2007 04:42
I'm also about to do set the float height on my 29's. Just so that I'm 100% clear on setting the float height, the carbs are upside down, gasket removed, now measure 23mm from the gasket surface to the top of the floats. Which is actually the bottom of the floats when the carbs are right side up. Am I correct?
I just want to be sure that I'm adjusting the floats correctly the first time.
Tom
Tom
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
