fuel in air cleaner...oh boy
- napkin13
24 Mar 2007 11:23
I have an 82 kz750 CSR. I just had the carb rebuilt and got it all put back together. When I tried to start it, i was getting fuel blowback into where the air filter is and its leaking onto the ground. It also wont start. I do believe the pilot jet is a 50 and i know its supposed to be lower, but I was told if I put on a bigger air filter it should be OK. I just wanted to see if anyone could help me on how the heck to get this bike to run! Thanks!!
- napkin13
Re: fuel in air cleaner...oh boy
24 Mar 2007 11:36
The fuel is literally pouring into the air box when i try to start it. It is also leaking out of the bottom of the two bowls on the carb...
- katjbus
24 Mar 2007 11:40
sounds like you have some debris stuck in the needle and seat or a sunk float
24 Mar 2007 13:05
napkin13 wrote:
Perhaps a reassembly mistake common to both carbs, so here are some random thoughts as to possible goofs.
Failed to replace a part related to float needle and seat (such as needle or seat or gasket or any combination) the float pivot rods or the floats themselves.
Installed floats upside down.
Installed damaged or leaking floats (so they both sunk, as previously mentioned).
Maladjusted float level tabs so the needles are not being pressed into their seats even if floats are floating.
Float bowls on backwards.
Float needles interchanged between seats and failing to properly seat in "wrong" seat.
Would seriously doubt the rebuilder did a float bowl service fuel level check, otherwise the overflow problems would have been evident.
Guess it's possible the carbs were perfect when put back on the bike, but were allowed to intake dirty unfiltered fuel which then promptly clogged between both needles and seats (as previously mentioned). Was an in-line filter being used at all times?
If good pure clean filtered fuel was admitted to the freshly rebuilt carbs both of which immediately began leaking out the overflows, it seems to me the rebuild was somehow at fault.
BTW, some of the excess fuel may have also made its way into the crankcase via the combustion chamber past the pistons and/or via the crankcase vent tube (if vented to bottom of air box). If any doubt about oil contaminated with gas, both oil and filter should be changed before running the engine.
- napkin13
25 Mar 2007 13:27
wow....you kick ass for all that advice...thank you very much!
- JimatMilkyWay
27 Mar 2007 18:12
napkin13 wrote:
That _was_ pretty cool stuff. Patton seems to know his stuff.wow....you kick ass for all that advice...thank you very much!
- kzwolfsr
27 Mar 2007 19:11
Do you set it on prime when you go to start it?
Original man of the Caribbean
