VM34RS
- WTF!
VM34RS
21 Mar 2007 15:59
Where do you start looking for a set of these carbs?
What bike models came out stock with the VM34's fitted?
Cheers
Cheers
- Duck
- e vica na i sau na ga
Re: VM34RS
21 Mar 2007 16:16
They are on the 1980 Suzuki GS1000 shaft drive (GS1000G)
You can pick up a non-runner cheap($100-$300) with some scouting. Only problem is it's a nice bike so you may be tempted to put it on road instead of rob the carbs. Linkage is different as the soozoo uses a center pull linkage for the choke. Really not a problem as you can add a cable pull choke perch from a Honda and have that nifty little, left thumb operated, lever for choking. Maybe use that gs1000 head with it's bigger valves too.
They are also on all the KZP with J motors.
-Duck
-Duck
- WTF!
Re: VM34RS
21 Mar 2007 20:12
Cheers Duck. Anyone know any other makes and models? Down here in the antipodes, we have to scrounge around used bike lots ferriting away for this stuff. It really makes it easy if you know where to start ferriting
