carb interchange????????????
- tbax
20 Mar 2007 10:47
Does anybody know if the carbs off a 2003 kawasaki zr7 will fit a 1981 ltd 750? Both look like they are of the old aircool design and I believe the carbs are both 34 and look similar. I have a chance to pick up a set for 75 bucks. Sounded like a good deal if they interchange. Thanks in advance.
- wiredgeorge
Re: carb interchange????????????
20 Mar 2007 12:47
I doubt that the engines have the same cylinder spacing. You can use carbs from any KZ650, KZ750, KZ900, Z1, KZ1000, KZ1000J style, KZ1100 for sure (possibly need some jetting changes, intake manifolds and cable changes as well as airbox).
- guitargeek
20 Mar 2007 16:52
Actually, I think the ZR-7 uses the same basic engine as the KZ750-4, and thus would have the same spacing.
As far as the carbs working? I don't see why not... but if anyone else knows better than me, please chime in!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- wiredgeorge
21 Mar 2007 05:05
Is the ZR7 air cooled? hmmm
- tbax
21 Mar 2007 07:28
Yes it is wiredgeorge. Air and oil-cooled. Got interested in the idea of haveing newer parts for an older 750. Who knows, maybe if the carbs interchange the other engine parts may also, opening up a whole new platform for building up the old 750s; including better availabiliy of parts.
- Paling1
21 Mar 2007 09:02
I also have a set of ZR_7 carbs waiting to be installed on my KZ700.
I'm not sure but maybe you have to buy the intake boots (between head and carbs) from a ZR-7, because they are different from the ones used on the old 750's, I'm also not sure if the boots between the carbs and the airbox will fit.
My KZ700 has Mikuni carbs, so it just might be an easy fit on an old Keihin carbed 750.
Recently I won a set of floatneedles and seats for my carbs on eBay. So I'm going to try to restore my old Mikuni's first. If they are still leeking, then I will try the ZR-7 carbs. They also have a floatbowl heating device attached.
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
- wiredgeorge
21 Mar 2007 12:23
I sent a note to one of our members who owns one of the ZR-7s but he didn't answer me on carb spacing. The spacing is critical. The 32mm flanges will fit into your carb boots BUT... look at the flanges. Each boot has a shape make to allow it to grab a specific carb. The 32mm and small engined 34mm BS series and Keihin CV34 all have the same type flange... the larger bikes with the 34s installed have DIFFERENT flanges on the 34s so the intake manifolds have to be the right type otherwise they may fail.
- tbax
21 Mar 2007 19:32
That's good to know about the boots. I believe the zr7s carbs are actually 32's so hopefully they will work. If not I'll probabably just buy zr7 boots.
- wiredgeorge
22 Mar 2007 10:01
The member who I asked for the spacing didn't answer. I get confused when folks who have asked me for advice in the past are not willing to share info we me. Oh well... If anyone can measure the center to center carb spacing on the ZR-7 carbs, it would be appreciated. Thanks The spacing for the KZ700 is 77mm - 93mm - 77mm; in other words 77mm between 1&2 and 3&4 and 93mm between 2 and 3.
- Mcdroid
- Gone Kwackers
22 Mar 2007 10:13
I think (naw, I know) that inline4 has a 2003 ZR7...someone needs to PM him:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- trippivot
23 Mar 2007 05:44
exact interchange
same engine same tooling simple as that
- Paling1
23 Mar 2007 09:13
trippivot wrote:
My KZ700 uses the same 4 for every cylinder. (16065-1132), but the KZ700 has Mikuni carbs whereas the ZR-7 has Keihin carbs, so this might explain the differences.
If I can find the time this weekend I'll try to measure my set of ZR-7 carbs.
Are you sure? Because when I have a look at the partsfiches, the ZR-7 seems to have 4 different carbboots. (16065-1256 to 1259)exact interchange
KZ700-A1 (1984)
