Float Level Check Tool
- BeeGee
07 Dec 2005 10:24
Has anyone seen this Kawasaki part? It screws into the float bowl where the drain plug is and provides an easy way of checking the float levels.
Kawasaki Part # 57001-208
Post edited by: BeeGee, at: 2005/12/07 13:27
- BeeGee
Re: Float Level Check Tool
07 Dec 2005 10:42
Here's a picture of this tool.
Someone has to have seen this before!
I'd love to get my hands on one. I've been trying to get a 6mm x 0.75 pitch male flow-thru type connector to make one of these up myself but I simply can not find the threaded hardware in that size thread. I can't even find a 6mm bolt with a 0.75 pitch. If I could then I could drill through the center of it and make a connection somehow from it to a section of clear fuel line. Anyone have any ideas?
Post edited by: BeeGee, at: 2005/12/07 13:51
- Mcdroid
- Gone Kwackers
07 Dec 2005 11:09
They are still for sale through cycle-parts.com BUT the catch is you must order at least $100.00 worth of merchandise to buy anything on this site. The price for 57001-208 is US$66.84 (shipping is extra).:ohmy:
Post edited by: Mcdroid, at: 2005/12/07 14:10
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- wiredgeorge
07 Dec 2005 11:24
Use a 1/4" vacuum fitting to screw into the 6mm/.75 pitch hole in a bowl. The 1/4" fitting is slightly larger than 6mm and a vacuum fitting is made of hard rubber/plastic stuff and once screwed in, won't leak much. The vacuum fitting is a straight through connector (connects two hoses). Then put a piece of clear plastic tubing on the end. Since I set the float levels in a set of carburetors almost every day, I stuck one in a float bowl and JB Weld-ed it in and it doesn't leak a drop. If you need a reference at the other end for the gas level, you can make your own marks I guess... there was also a Kawasaki tool that was essentially plastic tube that had gradient marks on it every 1mm. I had one and used to use it but it got brittle and fell apart. I recall I paid just under $20 from a dealer. This tool is used for many Kaw applications and you might want to look in a Vulcan parts listing under tools as I know it is there.
- BeeGee
07 Dec 2005 20:23
Thanks so much to the both of you:
Mcdroid for the source to purchase what I thought was both obsolete and unnavailable. I went to cycle-parts.com and sure enough the part is there.
wiredgeorge for the great idea of using a 1/4" vacuum fitting. I've been busting chops for the last few days searching out a source for a threaded fitting of the proper thread size.
Now, within a few hours of posting, I have options!
This is great ... Thanks again ... Brent
- wiredgeorge
09 Dec 2005 11:30
There is a Kaw float level tool on eBay right now. I think it would only work on Z1/Z1A bikes and is being sold by a seller from Sweden. I think it was at about $40... I am not trying to push anyone toward buying just pointing out you can look at one of these if you like while the auction is still running. I also believe it may have been marked as working on KZ900/KZ1000 bikes and I don't think it will based on the 17mm fitting you screw into the bottom of the bowl (like a VM28SC from 73/74).
- patmann
09 Dec 2005 12:34
cgi.ebay.com/ebaymotors/Kawasaki-Z1-KZ90...temZ4596569063QQrdZ1
Hopefully this works... There's one for sale on eBay as we "speak"
Pat
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- wiredgeorge
09 Dec 2005 13:10
That is the one I was referring to... It won't fit any of the bikes listed in the auction except the Z1/Z1A which use the 17mm NPT threaded fitting shown. The other/later bikes listed use a 6mm fitting with .75 metric thread.
- Ron G
09 Dec 2005 13:39Please Log in or Create an account to join the conversation.
- Jeff.Saunders
09 Dec 2005 14:25
ROn - different sized thread on the tool - I have one here and it works perfectly on the early Z1 carbs, but that's it - it doesn't seem to fit any others.
- JMKZHI
Last edit: 03 Dec 2008 20:15 by JMKZHI.
