Carb Baseline jetting
  • pistolpete
  • pistolpete's Avatar Topic Author
17 Mar 2007 10:47
#121017
I thought that I had seen a post on here where various people added their bike, mods, and jetting. I searched and couldn't find it.
Specifically I am looking for the needle hight, main jet, and a/f screw turns for a 77 750 twin w/ exhaust and pods. @5000ft +
Post edited by: pistolpete, at: 2007/03/17 14:06
  • JR
  • JR's Avatar
Re: Carb Baseline jetting
17 Mar 2007 17:11
#121133
I think there was one a long ways back - probably in the archives. Should be worth a check there.
Also probable someone with the answer will be aling soon
  • wiredgeorge
  • wiredgeorge's Avatar
17 Mar 2007 19:09
#121155
Some 750 owners can correct me here if I am wrong but I believe the KZ750B2 had the 3mm small headed main jet screwed into the float bowl. Unfortunately, this jet doesn't seem to be available anymore. I would think that the size of this jet would make it problematic as far as drilling but that would be one option. I suspect you would need to make it between #140 and #145. You can swap out the pilot jet going from a #45 to #45.7 and raise your jet needle by one slot (reclip). Clip to number four slot. I think the main problem is that the pods will run lean once you leave the upper mid-range... the BS carbs don't like small main jets in the upper rpms. If you drop by our vintage bike tech forum on our website, I might be able to come up with some work arounds to the main jet issue.
  • pistolpete
21 Mar 2007 13:38
#122304
I went through the archives page by page and found the jetting survey. It would be great to add more to it and make it a sticky.
kzrider.com/archive/viewthread.php?tid=18321
