KZ550C idle stumble ?
- jasenr
13 Mar 2007 23:05
I just cleaned and rebuilt my carbs for my 1982 KZ550C. It has a great deal of trouble starting, getting from choke to no choke and idle. It sputters when running under 1/8 throttle. It revs OK though. The bike has been messed with in the past as the mixture screw plugs are off. I currently have the airbox off and pods on while I am getting it fixed up. I still have the factory airbox. I just didn't want to put it on until I knew I could leave it on!
What should I look at? Mixture screws? Plugs? Simply put the airbox back on?
- JR
Re: KZ550C idle stumble ?
14 Mar 2007 04:58
Put the airbox back on. If you installed pods and have not put in bigger jets then it's not getting enough gas. Only getting enough gas when on choke.
With pods you always need to put bigger jets in the carbs
- jasenr
14 Mar 2007 08:18
I have been told that I can't get jets for my carbs. I have also been told that the pods don't have an effect until higher in the rpm band. I guess I have been told alot!
Have I been told wrong about these? Thanks!
- Wirewulf
14 Mar 2007 09:23
I think JR's right here. Any tuning you do with pods will be way off when you put the airbox back on. The pods will have some effect all through the rpm range. More air means leaner mixture = more choke necessary to get it to run. I know it's a pain in the rear to take the carbs out to work on with the stock airbox, but otherwise you're just pushin' the caca uphill. Hang in there, it sounds like you're close.
- JR
14 Mar 2007 12:47
Are your carbs TK?
If so then have you seen this post
kzrider.com/component/option,com_joomlab...w/id,119883/catid,3/
which talks about jetting for TK + pods
- jasenr
14 Mar 2007 21:22
Well, I replaced and set the mixture idle screws. I wasn't going to mess with them. Turns out that two were set different than the other two. I also changed the plugs. It seems to start and run easy now. Thanks for the tips. I am still going to put the airbox back on since it seems to be running good now! Thanks evryone! I rode twenty miles today. My first ride after the rider course.
- JR
15 Mar 2007 13:34
Thanks for letting us know how it turned out.
