jets for tk carbs?
- 1983kz550ltdc4
jets for tk carbs?
13 Mar 2007 16:48
gonna upgrade to pod filters and 4-1 went to my local bike shop and got a qoute on jets they wanted $121.00 + tax is this outrageous?? or is this the norm price?? anyone know of a place where i can get em cheaper? i know i have to go 3 sizes up on the main jet and 1 up on the pilot not for sure whats in it now but im pretty sure its all stock thanks - Shawn
- GPZK
Re: jets for tk carbs?
13 Mar 2007 20:55
I recently rejetted my 81 GPZ550, it also has the TK carbs. I found several references to using the small slotted main jets for Keihin (sp) carbs.
My local shop charged $9.95 ea, which I thought was a bit high, but he had them and I didn't.
From reading this forum, the pilot jets are not available anymore. I didn't even look for any.
Changing your needle clip setting, or shimming may be the only option for midrange jetting.
- CoreyClough
- GPz550 Addiction
13 Mar 2007 21:19
Dyno Jet makes Stage 1 and Stage 3 Jet Kits. They are the ame as the old K&N's of years past. Adjustable needle, drills for the slide, and to remove the stoopid(not a spelling error) caps on the air adjusters. Wotrh looking into. Usually sell on ebay as a kit for 1 and 3 for around $96.00.
LOOK! There's some now! :woohoo:
'82-'83 Jet Kit
'84-'85 Jet Kit
'82-'83 Jet Kit
'84-'85 Jet Kit
'85 GPz550(ZX550-A2)
- loudhvx
13 Mar 2007 23:03
What Corey said is probably gonna get you the widest range of tune-ability, and very good instructions on how to select the jetting. Luckily, the TK-22 carbs are the easy to tune since they are not CV. There are just fewer variables with them.
The el-cheapo option is to get a set of tiny drill bits and drill them. It's easier than you think, but you need a drill that has a chuck that closes down almost all the way. The cheap Menards tool-shop brand has a drill that works perfectly, and it's only $10 or $15.
The drill bits can be bought at various tool suppliers like Harbor Freight etc.
An in-between option is to get one of the various rebuild kits that come with jets and adjustable needles. (Some do, some don't.) They should be about $15 to $20 each X 4.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- JimatMilkyWay
14 Mar 2007 20:40
loudhvx wrote:
Cool loud; Thanks for the tip. I have bits down to about the diameter of a hair. The sets can be purchased in a neat little holder/organizer, from any jewelry or lapidary supply, or online. They will also sell you a nifty Grobet flex shaft grinder/polisher/drill with a Jacob chuck and foot control. They come in REAL handy, as does a visor with a #7 or #10 lens.....The el-cheapo option is to get a set of tiny drill bits and drill them. It's easier than you think,....
- loudhvx
15 Mar 2007 01:09
Yeah, hobby shops have them too.
Here's the set I have:
www1.acehardwareoutlet.com/html/product2102754.htm
Post edited by: loudhvx, at: 2007/03/15 04:11
1981 KZ550 D1 gpz.
Other links.
Other links.
- CoreyClough
- GPz550 Addiction
15 Mar 2007 05:18
Re-read the top, and at $40.00 per jet, they're smoking something that requires an alligator clip, and someone saying as they pass it to another, "here". :blink:
- 1983kz550ltdc4
- loudhvx
15 Mar 2007 23:55
Stages are just the level of performance increase, not necessarily jet sizes.
1981 KZ550 D1 gpz.
Other links.
Other links.
- CoreyClough
- GPz550 Addiction
16 Mar 2007 08:00
Stage 1 is for stock air box, stock exhaust, and maybe a K&N drop in air filter.
Stage 3 is for pod filters and aftermarket exhaust system.
If you buy a Stage 3, you'll get a Stage 1 kit in there too.
- pyxen
Re: New question Re:jets for tk carbs?
15 Apr 2007 10:24
Bump!
Question: I've still got my stock airbox, but 4-1 exhaust and stock jets - do I need to rejet? Should I go all the way like WG keeps suggesting with 2 steps on the mains and pilots? If so - what jets fit the CV TK-26s?
Do Keihins fit?
Lou - you have these on you GPzs, right? Or are they TK-27s..?
Oh..and how does the sizing of the micro drill bits work? a 61 would be .61mm? So if I have size 32 pilots, I need a 34 drill bit to up the size to .34mm? Same for the mains..a 120 main is 1.2mm?
After doing the coil mod, I notice that my bike kinda 'grunts' when I crank the throttle..it has a much louder/rougher sound to it than normal. I want to say it 'bogs' but it still pulls a lot..so it doesn't really lose power - I don't think anyways.
Thanks!
Post edited by: pyxen, at: 2007/04/15 13:29
Do Keihins fit?
Thanks!
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- vach
15 Apr 2007 10:52
pingelonline.com or call 888-4-PINGEL they are 2.50 a piece but you get charged $5.00 if you don't spend $20.00
Post edited by: vach, at: 2007/04/15 13:53
1979 kz650 B. Chicago, Illinois
