77 750 petcock??? ***Update***Thanks KZR and Z1 !!!
- got12narow
13 Mar 2007 15:20
I was checking the listings at Z1, and I had a question about replacing my petcock. If I purchase a new single outlet petcock, then will I have sufficient fuel flow by running a T to my carbs? Or.........should I spend the extra money (ha extra money!!!) on a dual outlet Pingel?
Thanks in advance,
Post edited by: got12narow, at: 2007/03/19 00:06
Post edited by: got12narow, at: 2007/03/19 00:11
Thanks in advance,
- Biquetoast
- King Jeremy The Wicked
Re: 77 750 petcock???
13 Mar 2007 16:20
got12narow wrote:
I was thinking about that myself for a while... I strongly suspect that there is enough fuel flow for a twin that way........ If I purchase a new single outlet petcock, then will I have sufficient fuel flow by running a T to my carbs?....
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- got12narow
13 Mar 2007 17:45
Thanks Toast. It's cheap enough from Z1 to give it a shot. I'll speak up again in a few days/week once I receive it and get it put on.
- got12narow
13 Mar 2007 17:45
Arggggg double post!
Post edited by: got12narow, at: 2007/03/13 20:46
- RonKZ650
13 Mar 2007 18:36
I run a 1977 KZ650 with the single outlet Teed off to double inlet KZ1000 carbs and it works great, so I'd wager to bet it would work fine on a 750 twin.
- got12narow
18 Mar 2007 21:10
Ordered the parts from Z1 Wednesday morning, and they arrived packaged very nicely Saturday with the post. I installed the single outlet petcock, T, fresh gas, and battery off the charger. DING DING DING! Fired right up. Plenty of flow and no more gas leaking.
Thank you Z1 Enterprises!
z1enterprises.com/
z1enterprises.com/
- Biquetoast
19 Mar 2007 13:24
got12narow wrote:
Just curious, do you run inline filters in that thing?
If so, now that you have a "t", do you use one filter or two?
Absolutely awesome... another twinner back on tha' road......DING DING DING! Fired right up. Plenty of flow and no more gas leaking...
kz750twins.com
kz750twins.com
