Fuel dripping from air box 81 KZ1000J
- 82KZ1000LTD
10 Mar 2007 14:05
81 KZ1000J, starts OK and than fuel starts dripping out of air box in a steady flow. All stock except carbs are 34mm carbs from a 81 LTD model and have the J model jets installed from carb kits. Whats going on. Thanks.
- kzwolfsr
Re: Fuel dripping from air box 81 KZ1000J
11 Mar 2007 21:06
I have the same problem on the 81 ltd like you say. I don't know whats up with that. Some would say that a pilot jet was stuck open.
Original man of the Caribbean
- FloridaBiker
12 Mar 2007 10:56
Your float level is too high.
You probably have a piece of dirt in your needle and seat...
or....
your needle is excessively worn and due for replacement.
or....
- kzwolfsr
12 Mar 2007 21:01
I choose float level, seeing I just cleaned out the dirt and the needles are in good condition
