40mm mikuni's klacking @ idle
  • myolkz1000
  • myolkz1000's Avatar Topic Author
06 Mar 2007 08:46
#117708
my bike a 78 kz1000 ltd has been bored out to 1100 and basic mods done to it like electronic ignition, the 40mm mikuni flat slides of course, dyna coils, a kerker 4 into 1, and my problem is not the bike running poorly or anything like that, i love it... its a friggin rocket. but at idle the carbs are making a klacking sound... but ive found that if i raise the idle higher this noise goes away but im idling at like 1700~1900 rpms way too high for my tastes and gas tank capacity.
Any suggestions or tips would be appreciated
thanks
  • Alex_KZ1K
  • Alex_KZ1K's Avatar
Re: 40mm mikuni's klacking @ idle
06 Mar 2007 09:04
#117715
Check it over for vacuum leaks. My 1000 did that after I put the carbs back on after a service. I replaced the intake manifold boots and found one of them had a crack. The problem went away.
  • 893cv
  • 893cv's Avatar
06 Mar 2007 09:07
#117717
You need to learn to enjoy that sound, cause all rs mikuni carbs make that noise. I have a set on my FJ1200 and it klacks too. The keihin flatslides have rollers on the slides so they dont klack as much.
Ride Well,
Jon
1980 kz1000 LTD
1978 Z1R
  • Z1109R Fin
  • Z1109R Fin's Avatar
07 Mar 2007 05:55
#118015
Yeap, thats how it is. Love that sound, got Mikuni TM33 pumpers on mine and that sound opens great comments when peopple hear the klacketi-klack -sound. Even brand new RS´s klack. Mikuni TMR´s are also with rollers so maybe not clacking so much.
Z1000R ´83...Slightly modified...
  • Z1109R Fin
07 Mar 2007 06:08
#118019
40mm flatslides:ohmy: Aren´t they kind of huge:unsure: I got 1109cc, slightly ported intake, very open 4-1 with a Kerker can (50mm baffle)and only 33mm Mikunis. Runs over 200kmh.
  • elseed
  • elseed's Avatar
07 Mar 2007 08:10
#118049
Confirmed, learn to enjoy the sound. Call 'em "Clackslides".
40 sounds huge to me as well. I think you normally stick with 36s or so for 1100cc street application. Maybe 38 for drag strip/top end. I've even heard of RS34s for 1100 street bike due to improved torque.
'75 Z1B with mods
  • wireman
  • wireman's Avatar
07 Mar 2007 10:46
#118088
this is a 1327 with more ungodly tricks done to motor than the local law would like .it had 38s on it ,but i took them off becuase it was no fun to drive.my engine builder has a really healthy sleeper 78 kz1000 with a really healthy 1385 that runs like a missile with 36s on it ;)
  • myolkz1000
10 Mar 2007 13:01
#119013
alright guys thank you very much for the info and approval basically i fogured cant be much wrong, but this bike was a mess when i got it. my father bought it for me as a project to work on to be able to ride next to him on his 75 Z1 that had been done by yoshimura back in the early 80's. his is fast but mine is faster RAWR! but basically after ground up resto including powdercoated frame all new bearings, bushings, and anything else i ran into that was just old. ill try to post pics in the future
  • Neiler
  • Neiler's Avatar
30 May 2007 10:10
#144883
got rs 38s on my gpz 1100 , klacking noise is standard it seem,s , so is insane mid range to top speed mwahahah:evil:
Ride free ... Neiler
