air cleaner boots question
- mykznme
04 Dec 2005 13:21
my boots are cracked prett bad and i was wondering if anyone has had this problem and how much beeter would the bike run if it was breathing right??
they look as if i messed with them a bit they'd fall apart
R.I.P. Odd Ivar
- Biquetoast
- King Jeremy The Wicked
Re: air cleaner boots question
04 Dec 2005 13:31
mykznme wrote:
Severely cracked boots are bad news. It can totally mess with performance and make adjustments muy dificil.
Consider getting replacements, but in the meantime, clean them up and cover them up with black silicone sealer stuff... others in the archive have spoken about doing this. I, myself, have done this on my 400 as a temp fix until I can get the boots off...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- mykznme
04 Dec 2005 13:53
i think the bike runs good now but it still sputters a bit.
rpms drag a bit aroun 6 grand then it kicks in at about 7 1/2
Post edited by: mykznme, at: 2005/12/04 16:53
R.I.P. Odd Ivar
- mykznme
- GargantuChet
04 Dec 2005 15:31
If you need to remove the carburetors more than once, it's definitely worth it to buy a new set of airbox boots.
Try Z1 Enterprises . They keep lots of stuff in stock for our old bikes, and the customer service is top-notch.
I've heard that leakage may cause performance issues, but some things are hard to diagnose. What I can say is that new boots will cure that "throbbing thumbs when carbs are removed or reinstalled" issue that's so troublesome to the bike mechanic!
- Alex_KZ1K
05 Dec 2005 06:08
GargantuChet wrote:
I can vouch for this... mine aren't even that old or cracked at all, and I still got throbbing thumbs when I removed my carbs last weekend. I'm replacing my airbox with pods in the spring anyways... I don't want to deal with those stupid things again.
- mykznme
05 Dec 2005 13:37question about pod filters. what holds the up besides carb?I'm replacing my airbox with pods in the spring anyways...
R.I.P. Odd Ivar
- DasTeufel
05 Dec 2005 16:38
mykznme wrote:
Pod filters use a hose clamp to connect them to the carbs, they are pretty light so not much else is needed for the pods. The carbs are held up by the intake boots, so make sure, if you go to pods, that your boots are in good shape and you secure the clamps good.
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
Wildomar, CA
- Alex_KZ1K
06 Dec 2005 07:14
Exactly. I've got new intake manifold boots on the way as well for that reason.
