pipe blueing
- arobsum
pipe blueing
04 Dec 2005 11:36
does lean carbs cause pipe blueing? will other things cause it? i have a 1977 kz1000 with 28mm carbs, 4 into 1 open vance and hines exhaust with k&n pod filters.
- JMKZHI
Last edit: 03 Dec 2008 19:23 by JMKZHI.
- wiredgeorge
Re: pipe blueing
04 Dec 2005 15:17
Please don't double post the same thread in different forums. Thanks. The answer to you question is that lean carburetion may blue your pipes but some bluing is normal in single wall systems.
