Petcock Question--What is this hole?
  • Skyman
  • Skyman's Avatar Topic Author
01 Mar 2007 14:52
#116505
I wanted an optional larger gas tank for my '78 KZ1000 LTD to use for longer rides. So I found one on EBay for cheap that bolts right on. It didn't come with a petcock, but had the bolt-on style holes.
I later bought the petcock seperately from the same seller of the tank (I assume this petcock is the original one from this tank). It is the vacuum style petcock--which I prefer, as long as it doesn't leak. ;)
There are three hose nipples on it. There is one near the top, which I assume is the vacuum connection. Then there are two at the bottom--one pointing straight down, and the other horizontal. I assume these are the dual fuel outlets.
Directly below the horizontal nipple, there is a threaded hole (M6 threads) pointing straight down, which connects with the passage that exits through the horizontal nipple--meaning that if I hook this thing up, fuel is going to leak from this hole.
My question is, what is this hole for? I assume I can just get a very short M6 bolt and plug it up, but what is its purpose? Anyone know what I am talking about?
Post edited by: Skyman, at: 2007/03/01 17:53
West Linn, OR
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: Petcock Question--What is this hole?
01 Mar 2007 15:24
#116511
Representative 78 vacuum petcock?
If it's what I think you are talking about, there is a drain on the bottom of the petcock that a bolt goes into. The $12.29 #27 bolt in the picture. . .
and don't forget, the non-available anymore washer.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
01 Mar 2007 19:17
#116555
2 thought come to mind...a sludge-drain,OR...some type of bleeder screw??(to prime the system)...maybe??:huh:
1977 KZ1000 A-1
  • Skyman
01 Mar 2007 22:31
#116614
Yep, I think that's it. I'm going to run right out and get me one of those fancy $12.29 plugs right now! ;)
Maybe I can find the washer on Ebay! :whistle:
West Linn, OR
