Rubber Vs Stainless Needles
  • JimatMilkyWay
  • JimatMilkyWay's Avatar Topic Author
28 Feb 2007 13:54
#116147
Let's try this again for the third time, shall I!? I apparently threw away two posts in a row, somehow.
My VM's are seeping fuel. The stainless steel float needles are bright, shiny, clean and show no signs of erosion on the side. I have not tried polishing the seats, like by hand, using a q-tip and some rouge, for example, or should I not even touch the seats with anything.
From your experience, do the stainless needles seal completely or do I need to replace them with rubber tipped ones?:huh:
Post edited by: JimatMilkyWay, at: 2007/02/28 16:56
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: Rubber Vs Stainless Needles
28 Feb 2007 14:14
#116151
In my opinion, the rubber ones would seal better. Once you see a ring around the tip, where it sits from the hole it's closing, replace it/them with new ones, as they aren't sealing as good anymore. I haven't seen metal ones in a long time. Most rebuild kits come with rubber-tipped ones, probably why I recommend them. ;)
'85 GPz550(ZX550-A2)
  • RonKZ650
  • RonKZ650's Avatar
28 Feb 2007 15:05
#116168
Either type will work fine and you could leave your gas on forever theoretically and not leak a drop. I had an old H2 that the petcock would leak when it was in the on or reserve position (vacuum operated petcock), but the petcock would not leak in the prime position, so I left it on prime for many years and the carbs never seeped a bit. If your needles/seats are leaking it's time to replace them. No use fighting them leaking.
  • JimatMilkyWay
28 Feb 2007 22:45
#116303
Thanks Corey and Ron for the help.
Absolutely stopping fuel at the float/bowl is in fact all I will ultimately accept, whatever it takes.
While the carbs were __supposed__ to have been rebuilt and while they __are__ very clean inside and out, they still seep. Not sure exactly which just yet, as I am going through electrical issues now and wish to finish that before taking carbs off, again, and again and,,,.
Will get back to youse guys.
