What are those plugs on my carbs?
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: What are those plugs on my carbs?
23 Feb 2007 17:45
#114835
If they are between the carb and the intake manifold, it's a vacuum port. If it's between the carb and the air filter, it's a bowl vent.
'85 GPz550(ZX550-A2)
  • arobsum
  • arobsum's Avatar
23 Feb 2007 20:10
#114857
they look like stock vm28's to me. some had accel. pumps, some didn't. those came on late 70's kz's. as far as 4 individual ports? don't know!!:) i have a set and they only have 2...
Post edited by: arobsum, at: 2007/02/23 23:12
  • austin3119
  • austin3119's Avatar
23 Feb 2007 22:18
#114887
I had to order a set of those plugs for a set of carbs I rebuilt. Z1 Enterprises carries them.
  • JimatMilkyWay
  • JimatMilkyWay's Avatar
24 Feb 2007 05:44
#114920
Conti wrote:
....I'll take some closeup pictures of the carbs....
The pics you already took of the carbs are really nice. Too bad about the cat.
  • The Fish
  • The Fish's Avatar
24 Feb 2007 05:53
#114923
In your first pic, the passage on the outside of the carb (where the gas passage would have been) looks like it might be plugged with epoxy. It looks like your set may have been made from combining 2 sets of carbs with 2 X #2 position carb and 2 X #3 position carbs. That would explain the many ports on your carbs.
They should work fine, but make sure that all the bowls have some sort of vent. Plugged bowl vents can cause all sorts of erattic running. And make sure that the vents that have vacuum when running are plugged or ran to your vacuum petcock.
Fish
  • JimatMilkyWay
24 Feb 2007 07:41
#114939
The Fish wrote:
In your first pic, the passage on the outside of the carb (where the gas passage would have been) looks like it might be plugged with epoxy....Fish
Where is the epoxy? I can't spot it.
  • The Fish
  • The Fish's Avatar
25 Feb 2007 10:02
#115258
On the left side of Conti's carb, below the idle mixture screw, where the gas passage would be located.
If you look at Rons carb, the same spot is open (not filled- yes, they are pumper carbs but the later VM series look like Rons on the outside).
It looks like an inner carb body may have replaced the outer left carb body. If this passage wasnt filled, the carbs would leak gas out of it.
The carb gas passage could have had the other side of the passage drilled (or it may have been open , depending on the application) to get it to work correctly.
Fish
  • Conti
  • Conti's Avatar Topic Author
25 Feb 2007 14:56
#115328
@The Fish: you're right, the passage of th carb #1 is plugged with something:
Moreover, the carbs do not get the same numbers engraved:
:blink: :blink: :blink:
Anyway, I cleaned the carbs on today:
I'll replace the needs, gaskets etc on next week-end. The float needle of carb #3 was sized!
  • arobsum
  • arobsum's Avatar
25 Feb 2007 14:59
#115330
fish stated on here that 2 of those look like they had been "converted". he was right on the money. good catch!:)
Post edited by: arobsum, at: 2007/02/25 18:01
  • 2bskor
  • 2bskor's Avatar
25 Feb 2007 18:07
#115378
I have a 1979 kz1000st also and that is the vacuum that goes to your fuel tank petcock. If this wasn't connected your bike shouldn't have run, unless you have a different petcock.
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
  • The Fish
  • The Fish's Avatar
25 Feb 2007 18:57
#115392
The carbs should work fine, just make sure all the parts (jets, needles, etc.) are the same on all 4.
Check the slides to be sure they are the same (the cut out size is stamped on the bottom of the slides)
Let us know how it works out for you,
Fish
