Has anyone seen this before?
- The Fish
20 Feb 2007 04:11
About a year ago I bought a bunch of carbs at a bike shop auction. These carbs were in the box of carbs. They are the 1975 Z-1 VM28s. They have been bored out to 29mm. On the air box side the the choke passage has been smoothed and the air jets have been "free-ed" from their original casting (the set on the bottom, the top set is a set of stock Z-1 for comparison).
Anyone seen this before?
Fish
Fish
- The Fish
- Duck
- e vica na i sau na ga
Re: Has anyone seen this before?
20 Feb 2007 05:41
Would be curious as to how well they work in the range between idle and WOT
Can you mount them up, make a few runs, and report back?
- wireman
20 Feb 2007 06:57
ive seen a lot of milling of airhorns and stuff like that on holley 4 barrels but not much on bike stuff,im guessing somebody was loaded for bear with that combination;)
- Duck
20 Feb 2007 09:42
There don't appear to be any slides installed. Without slides, the only option for engine speed control is 'blipping'. Makes them useless for anything but drags. WG has probably seen something like these but along with gris and a few others, has been scarce lately.
fish-
would you happen to have a set of carbs and holders suitable for use on an old CB400? To trade, I have a couple of MIC BS34 with good(no scuffs) slides and good(no leak or patch) diaphragms. Pretty much all that is missing is the linkage for choke and throttle.
Post edited by: Duck, at: 2007/02/20 12:45
fish-
- wireman
20 Feb 2007 12:35
they probably just havent had the slides reinstalled yet;)
- The Fish
20 Feb 2007 15:31
The carbs are complete, I just havent put them together yet. I was rebuilding them and when I started to look closer at them and I noticed they were different from the other Z-1 carbs I have. I replaced the choke plunger spools with a set of aluminum spools.
I will probably try them out (closer to spring) when I remove my turbo.
I got a bunch of carbs that are unmarked. So I may have a CB 400 set. Can you post a pic? I dont want any stinkin' CV carbs for trade so you would need to buy them out right.
Fish
Fish
- The Fish
18 Apr 2007 05:13
I couldn't tell any difference in performance from the 2 sets of carbs pictured. Maybe on a dyno, there would be a 1/3 of a hp difference, but in real life (on the street) both carbs worked well and performed the same.
Fish
Fish
