petcock problems
- arobsum
- Prune1
- kzwolfsr
Re: petcock problems
11 Feb 2007 16:39
I think I know what you are talking about Prune1. On my 1000 LTD the petcock switch doesn't turn without knocking the carburettor, so I lift the tank a little to give it some clearance, plus I dont use prime anymore since its so much work to move it.
Original man of the Caribbean
- Sandy
- Fly High,Tony
11 Feb 2007 19:34
Prune...I'm using this petcock from Z-1 Ent.,and I have 2inches of clearance between the bottom edge of the tank to the bottom of the petcock.
I would snap a pic,but the bike is tucked tight against the garage door right now,with the left side against the door.
Here's a link to the petcock...
www.z1enterprises.com/detail.aspx?ID=27
1977 KZ1000 A-1
- Prune1
13 Feb 2007 06:50
alright im thinkin about that sandy...although i would pick up a dual outlet. I cannot find any specs on how long the body of the valve is. does anyone know where to find that or have some specs for me? I just want to be sure before i spend my tax return on a pingel! :silly:
- Sandy
- Fly High,Tony
13 Feb 2007 22:01
Prune...ask Jeff Saunders(Member here,and He runs Z-1 Ent.,if You didn't know already)...see if He can help You out there,Bud.
1977 KZ1000 A-1
- Prune1
24 Feb 2007 16:01
just to let everyone know that the Pingle dual outlet does fit very nice with these air cleaners.Its almost as if it were made to tuck right in there. jeff at Z1 hooked me right up.
- jeffreygp
01 Mar 2007 11:59
Had frabricated a simple adaptor with a nipple to replace the petcock,a friend turned one on a lathe ,it looks like a fat washer(around 3/8" thick) with a half inch nipple at the center,drilled 2holes to match the mount screws,had to remove some material on one side to clear the lip of the tank,and used gaskets I cut from a piece of neoprene sheet. I used an in line fuel petcock used for boats, coz it was the cheapest I could find.Used the setup for a few months while I was waiting for a decently priced petcock (new ones are expensive). And still being used now by a friend with tank setup problems.
Post edited by: jeffreygp, at: 2007/03/01 15:20
