Re-jetting a KZ440
- stone_cold
Re-jetting a KZ440
08 Feb 2007 14:08
O.K guys, the advice for jetting my KZ1100L1 was right on the money and it runs so well I now want to rebuild the carb on my KZ440D1.
It's a 1980 KZ440 LTD D1 belt with the point system and the stock Keihin 36mm carbs and (at least for now) the stock exhaust system. I want to rebuild the carbs and add pods because my air box has been modified by a PO and I just like th eway the pods look.
My question is about jetting. The 36mm carbs have a primary and secondary main jet so I'm not sure which I'd need to change when adding the pods nor what size to use.
I searched the Z1 site and found the kits but all the Keihin jets that are listed for a Kawasaki are huge compared to the 60 something's that are in there now. Z1's jets start at #105 so that seems like a huge jump to me.
Do any of you guys have any advice for me on this??
I'd also like to know if there is a reasonably priced 2 into 1 aftermarket exhaust for the 440LTD.
Thanks for your help.
Tony T
Tony T
- Robjb84
Re: Re-jetting a KZ440
09 Feb 2007 07:00Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 319. Please enable debug mode for more information.
- JR
09 Feb 2007 10:44
I'm delighted to hear that the larger Keihin jets are available from Z1. I thought they were impossible to get.
Now...if you find a source for the smaller 60 / 62 ish size let me know.
In the meantime you might find jetting advice on www.kz400.com which is a great source of info
Post edited by: JR, at: 2007/02/09 13:45
