stock rubbe hoses??
- kustompup93
stock rubbe hoses??
05 Feb 2007 12:04
ok i have a question. wat do i do with the rubber hose that comes from the stock air box 2 the the engine?? any one know wat 2 do when u putting on those (4) air filter pods, and wat 2 do with the rest of the rubber hoses that are stock from the air box? should i buy a mini air filter from z1 for the crankcase??
- Wirewulf
Re: stock rubbe hoses??
05 Feb 2007 12:51
Not sure what type of scoot you've got, but generally speaking, yes, you can put one of those small filters on the crankcase vent. When I switched to pods on my 750 I just pulled out the hose going to the air filter and ran one directly between the two valve cover connections to block it off. Hope that helps
