carb bowls
  • arobsum
  • arobsum's Avatar Topic Author
carb bowls
04 Feb 2007 18:47
#110239
does the later style vm28 and the vm26's use the same bowl? i want to convert my fuel pump vm28's to non fuel pump. thanks for your time.
  • wireman
  • wireman's Avatar
Re: carb bowls
04 Feb 2007 18:59
#110242
i know you can use tops and bottems from 26s on 29s,im guessing you can also use them onnewer 28s;)
  • arobsum
Re: carb bowls
04 Feb 2007 19:24
#110254
cool! just what i wanted to hear...thank you.:)
  • arobsum
Re: carb bowls
08 Feb 2007 16:09
#111057
does anyone have some bowls they want to part with?
maybe some good old fashioned horse trading....
  • RonKZ650
  • RonKZ650's Avatar
Re: carb bowls
08 Feb 2007 20:31
#111100
I think even the 24mm use the same bowls. Of course different bowls were used for the accelerator pump carbs, but as far as I know the standard carbs all use the same bowl.
  • arobsum
Re: carb bowls
09 Feb 2007 15:00
#111216
i am doing away with my accel. pump so i don't need these bowls anymore. i would rather have the other style on them. besides, the accel. pump lever is missing on mine..;)
  • kzwolfsr
  • kzwolfsr's Avatar
Re: carb bowls
09 Feb 2007 17:53
#111259
Hey Captain! Did you see the My Ride post? Check it out! I can get you your bowl or then again you can go to www.steelescycle.com
Original man of the Caribbean
  • The Fish
  • The Fish's Avatar
Re: carb bowls
10 Feb 2007 06:12
#111331
If your present bowls have the check valves and balls in them I may be interrested in a trade. PM me.
  • arobsum
Re: carb bowls
10 Feb 2007 08:15
#111334
thats a cool site kzwolfsr!! looks as if you can get anything there. thanks.:)
  • RonKZ650
  • RonKZ650's Avatar
Re: carb bowls
10 Feb 2007 10:53
#111370
Rick at Steeles cycle is a fair guy. Don't expect a lot of friendly chit-chat, he seems rather unfriendly, but a good guy. I've been going to that salvage yard since the early 70s. Been around a long time. Everything is out in the weather unfortunately, so don't expect much in the way of cosmetics.
  • kzwolfsr
  • kzwolfsr's Avatar
Re: carb bowls
11 Feb 2007 16:23
#111635
That's very true there Ron. I would swear I was ignored when i go to that place its like I am invisible and no one cares. I just say I am going into the junkyard, sign the list and I am out of there. I seen the carbs you are looking for Captain, I walk on them all the time. Right now the snow has them covered so it will be awhile. Hey Ron did you go riding today. Good 56 degrees man. I drag raced my 1000 to cherry creek, but I have loud exhaust so I release my clutch and go stealth once I have the speed wounded up. Real fun!
