Wrong carb kits!
  • sbodi4d
  • sbodi4d's Avatar Topic Author
Wrong carb kits!
01 Feb 2007 21:16
#109649
I ordered kits for my 1980 KZ1000E2 Shaft from Z1, I started to rebuild the carbs this evening and low and behold the kits I received are wrong. Has anyone else had this happen? The air mixture screws are too long and diameter is wrong, there is not an o-ring for the outlet check valve and the main jets are marked 102 & 105, my jets are 110 which is what the manual says they should be.
The kits are marked 18-2610 which is what the Z1 site shows for my carbs, but I think someone packaged the parts wrong, unless the carbs on my bike are not stock. I don't know how to tell which carbs they are, anyone else know how to tell? I have enjoyed this site very much since joining and have learned a lot so far.
Thanks for all the help.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: Wrong carb kits!
01 Feb 2007 21:44
#109652
If they are the K&L kits, I have seen jets that didn't match up with spec for the bike. I have also seen a lot of old bikes with carbs that did not match up with what the FSM said should be on them. If it was easier, used bikes would cost more :-)
  • inline4
  • inline4's Avatar
02 Feb 2007 08:05
#109703
Excellent point, Duck.
  • RonKZ650
  • RonKZ650's Avatar
02 Feb 2007 10:04
#109722
Here's a picture of ST carbs. You can spot them easily because the choke lever is different than any other Kawasaki. (Shaped different to hang lower). The internals I'm not sure about.
  • sbodi4d
02 Feb 2007 10:25
#109728
That looks just like my carbs, except it has caps on the air mixture screws and mine don't. PO probably took them out at some time. I work in the parts department of a construction Equipment Dealer, so I know all about wrong parts.:angry:
  • rckz
  • rckz's Avatar
02 Feb 2007 15:58
#109778
On the Z1 website it says "For the shaft bike (KZ1000E), you will need to reuse the existing main jet."
  • rckz
  • rckz's Avatar
02 Feb 2007 15:59
#109779
  • sbodi4d
02 Feb 2007 19:53
#109826
Yeah I just noticed that earlier.:pinch:
I kinda stopped reading after I saw the KZ1000A3/B3 E1/E2. :angry:
I think Jeff is going to help me out of my dumba$$ mistake. :ohmy:
Post edited by: sbodi4d, at: 2007/02/02 22:55
