New-to-me kz1000 with nasty carbs ...
- rckz
30 Jan 2007 14:01
I just picked this bike up cheap and it needs a bit of help. The carburetors look like a solid piece of varnish and I'm not looking forward to pulling them apart. It's a 1980 kz1000e (st?). From what I've read here it probably has the 28mm accelerator pump carbs. Since I'm interested mostly in low-end grunt, would it make sense to try a set of 26mm carbs? Advantages/disadvantages? Thanks.
-Doug
-Doug
- Mcdroid
- Gone Kwackers
Re: New-to-me kz1000 with nasty carbs ...
30 Jan 2007 14:23
Well Doug, with all that money you saved on the shaftie, take some of it, pull your carbs and send them to WiredGeorge and let him do his magic (it's worth it!)...don't go to smaller carbs:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- ltdrider
30 Jan 2007 14:25
I agree with Mcdroid. I've got 26's on my 900. They're OK for my kind of riding, but every 900 prior to '76 had the 28's. Those pre-76 bikes are wild ponies, but that's what helped make them famous.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- RonKZ650
30 Jan 2007 16:00
I agree with the guys to a point. If at all possible keep the right carbs, but I doubt personally there would be any detectible power gain or loss going either way from 26-28mm.
- arobsum
30 Jan 2007 16:02
well, i took the 26's off my 1000 and put some z1 28's on it. i could tell the difference.
- wireman
30 Jan 2007 18:33
yeah if youve already got the 28s id say go with them,anything up to 29s will give you plenty of torque and should fit wit minimal hassle
- donthekawguy
30 Jan 2007 22:11
Stick with the 28's. You might want to find a new set on ebay. The 26's suck! They are ok for putting around town but if you want to move you will be dissapointed.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- rckz
31 Jan 2007 07:06
Okay, guys, I'm convinced. I'll have a go at cleaning them up myself, then go from there. Thanks for the input..
- rckz
03 Feb 2007 19:38
Well, I got the carbs off today. Man, those airbox boots were hard. I finally had to saw two of them in half in order to get any maneuvering room. So, now I'm wondering 1) what's a good source for boots?, and 2)should I just skip it and install pod filters? I'm leaning towards 2). By the way, what's with that convoluted air intake thing. I guess it's to keep things quiet or something, but I've never seen anything quite like that. A marvel of engineering. One good thing ... I found my kickstart lever. Cool!
I was tempted to use wiredgeorge's service (sounds like a good service and a decent deal), but the truth is I kind of like doing these things myself ... and I'm cheap. So I have some carb kits coming, but now that I have the carbs off, I see other little bits and pieces (such as the plastic bushings on the choke plunger) that will likely need to be replaced. What's a good source for stuff like that? Thanks again for the responses.
-Doug
-Doug
- pumps
03 Feb 2007 19:50
I'm going to have to recommend
Z1Enterprises
Jeff is a member here and is very knowledgeable on our bikes. Go to their site and look and if you can't find what you need call or email and I think they can help you.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
