Need Some Jetting Recommondations...
  • xsjunky
  • xsjunky's Avatar Topic Author
28 Nov 2005 08:54
#10653
I have stock exhaust but no airbox. So, I will be adding pods and was wondering what jetting needed to be changed.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Need Some Jetting Recommondations...
28 Nov 2005 09:56
#10665
The 77 LTD was very lean. Suggest #115 mains / #17.5 pilots. Leave the jet needle clipped as it is initially as you didn't mention pipes so I am going to assume stock OR baffled aftermarket. While you are doing this, remove your pilot fuel mixture screws and put new orings on them. When you screw them back in, screw them in so the tips are just barely flush with the openings in the venturis and back them out 1.5 turns.
If you are lean off idle, turn them out an additional 1/4 turn and retry and if there are any flat spots, reclip to 4th position (5DL31-4). The 77 LTD carbs had a bit smaller needle jets and can run a tad lean if the exhaust used is free flowing.
  • xsjunky
28 Nov 2005 19:35
#10774
the exhaust is indeed stock...for now. Any suggestions if I do get my hands on a 4-1?
  • wiredgeorge
29 Nov 2005 05:35
#10860
Try the set up I described with the 4 into 1 WITH baffles. Sorry I didn't see the stock exhaust when you posted it... For stock exhaust and no airbox, try the same set up with #112.5 mains and if you decide to go with a 4 into 1 and NO baffles with no airbox, I am sure #117.5 mains would work fine.
The TYPE of pipe can make a difference in the mid-range. Baffles pretty much ensure you will not have any BIG flat spots. If you use straight pipes, a flat spot MAY appear and then you will have to tune the jet needle / needle jet combo to rid yourself and this is a matter of experimentation.
