GSXR carbs
- jasbarsydvic
- 77KZ650
Re: GSXR carbs
16 Jan 2007 18:18
I think the older gsxr carbs (oil cooled motors) have the same spacing. then its just a matter of getting the right intake boots.
Scott
Scott
07 MDP Rookie of the Year
- jasbarsydvic
- 77KZ650
Re: GSXR carbs
16 Jan 2007 20:01
did some research for ya. according to sudco, the mikuni rs aftermarket carbs that fit the KZs (650, 750, 900, 1000, 1100 all have the same spacing) also fit the following list, meaning the spacing is the same, so a set of stock carbs could be adapted aswell
these ones are in the 34mm list
GSX600 1988 GSX-R750 1986-1987 GS750 ALL
these ones are 36mm list
GSX-600 1988 GSX-R750 1988-1992 GSX-R1100 1987-1992 GS1000-1500
in the 38mm list
GSX-R750 1987-1992 GSX-R1100 1987-1992
so anything from those lists, just pick what one is suited to the motor you are going to build
in the 38mm list
- Z1109R Fin
Re: GSXR carbs
17 Jan 2007 02:51
The two inner cylinders in GSXR are a few millimeters closer than in a KZ. They will fit but needs a little "muscle" and I´d advice to get new carb boots.
Z1000R ´83...Slightly modified...
- jasbarsydvic
- Bic Darklighter
Re: GSXR carbs
20 Jan 2007 08:28
I have em on my 900... one problem, the float bowl is at a 10 degree angle due to the :lay down: aspect of the GSXR. The run fabulous but I'm having trouble withthe idle air screw setting...... Personally, I think I'm going to pursue a set of BS34's.
and yep, some muscle does overcome the two inner cylinder spacing imbalance
Post edited by: Bic Darklighter, at: 2007/01/20 11:30
\'76 KZ900
\'74 KZ400
Thorold Ontario Canada
\'74 KZ400
- jasbarsydvic
- Z1109R Fin
Re: GSXR carbs
02 Feb 2007 04:37
I got Mikuni TM33-8012 pumpers. They were used in bigger GSXR´s. Flatslide smoothbores with acc. pumps and no vacuum:laugh:
Runs like a maniac up to 10000rpm / 210kmh (speedo, not radar), terrific throttle response and power. Still have some work to do, little laim on 2-4500rpm.
And the sound with K&N ovals and slides slapping :evil:
- MarkTore
Re: GSXR carbs
02 Feb 2007 21:22
Not to hi-jack this thread but I have a few question on GSXR carbs VS RS 34 Smooth Bores.
1. If I am running no air box and aftermarket tank without vacuum lines would the GSXR carbs work as good as flat slides.
2. Do the GSXR carbs / RS 34 have two or one fuel inlet.....if two what do you think about using a single petcock tank with a double feed petcock.
This is for a chopper project.
Thanks in advance.
Mark Tore
Thanks in advance.
Mark Tore
- Z1109R Fin
Re: GSXR carbs
05 Feb 2007 04:04
Which GSXR carbs? The more agressive TM33 Flatslide-pumpers or the more street-easy CV -carbs?
Some say that with CV carbs you should use the stock airbox since pods like K&N ovals do not generate enough or as stabile vacuum as the airbox. With CV carbs use the airbox and with TM33´s or RS34 use K&N pods.
I´d recommend Pingel Hi-Flow petcocks. RS34 have two inlets.
In Bic Darklighter´s pic is a CV -carb.
Here´s a pic of the TM33-8012 -pumpers:
- Duck
- e vica na i sau na ga
Re: GSXR carbs
22 Mar 2007 10:16
77KZ650 wrote:
FWIW
Stock GSX600F
Carburetor 1988-1997: Mikuni BST32 x 4
-Duck
in the 38mm list
FWIW
Stock GSX600F
-Duck
