78 kz650 carb teardown/cleaning
- hemlock
15 Jan 2007 10:57
Can you guys give me a rough idea of what I'm getting myself into time/$ wise in removing, cleaning, replacing components of the carb system on a 78 kz650? i'm decently mechanically inclined, and have the diagrams, but have never attempted to tackle a motorcycle motor before.
just trying to make sure i avoid the land mines before i start to take things apart in search of my leaky carb problem...
- OKC_Kent
Re: 78 kz650 carb teardown/cleaning
15 Jan 2007 11:23
It won't be too hard because you're mechanically inclined, but it takes a little time. Mine took a few days because I am s-l-o-w. I'm sure it can be done in a day or less.
Buy the carb kits, check www.z1enterprises.com & print off diagrams for your carbs from the Kawasaki website or your manual. I suggest getting a gallon of carb dip like Berrymans, and you will need compressed air. If you don't have a compressor then buy cans of compressed air in the computer section at Walmart.
I tore apart and dipped one carb at a time. Use the other carbs as a reference in case the diagrams aren't clear. Don't dip plastic or rubber parts like orings, they will get soft and tear. Dip the metal parts, scrub them with a brush, keep at it until they are clean. Rinse in water then blow dry. Don't shove wires into your jets, let the chemical do it. Your kits probably come with jets anyways, so act accordingly.
Check out this link too. It's just one of many carb cleaning webpages on the 'net.
kz650files.kz650.info/word/CarbCleaning101.doc
Have fun and write back.
Cashion, OK
78 KZ650 B2 85,000+ miles
- hemlock
15 Jan 2007 11:38
Thanks for the confidence booster there...i was hoping it would be a relatively straightforward process.
I'll try to post some before-during-after pics and updates using your suggestions. i guess if nothing else, it could be a testimonial to the fact that the process works.
- hemlock
Re: Leaky Carb Pics...Ideas?
15 Jan 2007 20:10
Here are some pics I just took of two leaky carbs. I just brought her home yesterday, so haven't taken anything apart yet, but at first glance, it seems to me like the leakiness on these might be addressed by a good cleaning a couple of new gaskets.
Of course, I solicit more experienced opinions...
FYI, these are pics of the bottom of the 2nd and 4th carbs (counting from the left) on a 1978 KZ650 D1. The 2nd appears to be leaking very old/discolored fuel, while the 4th is dripping clear fuel. Both drip at a rate of maybe 1 drop per hour or two. The bike hasnt been started in about 5-6 months, and has sat outside uncovered during that time, until I brought it here yesterday.
Thoughts as to first steps?
Post edited by: hemlock, at: 2007/01/15 23:12
- hemlock
- kzwolfsr
15 Jan 2007 20:37
Well from what I see you have leaking gaskets. But as OKC said it doesn't take to long for me at least to take apart the carbs, at least for me. Do 'em once and its smooth sailing after that. I didnt use what OKC uses, I used Gumout carb cleaner, the one you put in the gas tank to run it through the engine. It woks nice and I don't blow it off after cleaning the parts cos it seems to have a lubricating feeling to it so it keeps the carb parts well lubed for assembly. I have pics but don't be confused, my bike just has a accelerator pump
Original man of the Caribbean
- kzwolfsr
15 Jan 2007 20:40
I also got a carb base gasket kit from
for like less than 10 bucks if I remember good, plus some o-rings
- hemlock
16 Jan 2007 06:03
thanks kzwolfsr for the help. I figured the gaskets were shot and would need replacing, but i had visions of a several day process. hopefully i can knock it out in one day of work. i guess its off to Z1E now to order some supplies...
