kz550 bogg help needed!
- OutsiderZX12R
Re: UPDATE PLS HelpRe:kz550 bogg help needed!
07 May 2007 16:01
How do you adjust the idle mixture screws? Do you have to remove those covers they put over them?
- 77KZ650
07 May 2007 16:21
"slider" from .org? that you? fire up a new thread in the new members. welcome btw
I think you are talking about carb synch, (take off the tops of the carbs to adjust) idle or air screws are on the side. little brass ones with a spring behind them IIRC
07 MDP Rookie of the Year
- OutsiderZX12R
07 May 2007 16:59
What's up Scott? It's me. I am talking about the idle air screws that would normally be located at the back of the carb by the air cleaner. Mine have a cap over where the screws should be. Is it as simple as removing that cap?
- 77KZ650
09 May 2007 14:53
I just checked the parts diagrams on the kawasaki site for an 82 550. they show a plug over the screws, just pop it out;)
the plug is part# 92066-1051 "PLUG,PILOT SCREW"
KZScott
KZScott
