28mm carbs with accel. pump
- arobsum
13 Jan 2007 20:59
i found a set of 28mm carbs with accel. pump at a parts place i know. it looks as if someone tried to disable the accel. pump because the little brass squirt tubes
(4 each) had been removed. would these carbs still be functional and worthy of messing with without the accel pump and associated hardware? i am sure i could pick them up for a song.
- Bluemeanie
Re: 28mm carbs with accel. pump
14 Jan 2007 06:18
Mine have a pump whick I'm still trying to dial in, but for years they did not and worked just fine when jetted properly! Just my thought but I think they will be fine. I believe you will want to block off any ports associated with the pump, fuel, vacuum, etc.
- arobsum
15 Jan 2007 08:52
ok, thanks! now, would these style 28's be better than the earlier z1 28's? thats what i'm running now..
(i sold my 29's). if the later ones work better i may upgrade.
- chetriply
17 Jan 2007 09:28
I've got a set of 79 Non accel. pump VM 28's and they run great. I don't know if there are differences (aside from the accel. pump) in these carbs though. I rebuilt mine and jetted them for pod filters and a 4 into 1 and they scream.
- arobsum
17 Jan 2007 15:28
chetriply wrote:
cool, thanks! where is houston? i grew up 60 miles north of hannibal, in clark co. missouri. (kahoka)I've got a set of 79 Non accel. pump VM 28's and they run great. I don't know if there are differences (aside from the accel. pump) in these carbs though. I rebuilt mine and jetted them for pod filters and a 4 into 1 and they scream.
- 77KZ650
17 Jan 2007 15:41
I think I read somewhere that the newer 28's stay in sync better.
Scott
Scott
07 MDP Rookie of the Year
- arobsum
17 Jan 2007 16:29
this is good news...i could probably pick these up for $25.00B)
- chetriply
18 Jan 2007 13:06
Houston is in South Central MO. About 45mins. south of Rolla.
