stock carb size
  • hydrolazer
  • hydrolazer's Avatar Topic Author
stock carb size
27 Nov 2005 16:55
#10509
does anyone know off the top of their head what size/kind carbs came on a stock 79 kaw 1000 ltd?,,,thanks
Post edited by: hydrolazer, at: 2005/11/27 19:55
\'79 kaw 1000 ltd
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: stock carb size
27 Nov 2005 17:16
#10513
Welcome to KZR hydrolazer. A book I have states the 1977-78 KZ1000LTD came with VM26 Carbs and the 1977-80 KZ1000/MkII/E came with the same VM26 carbs, but it doesn't list for a 1979 KZ1000LTD.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • wiredgeorge
  • wiredgeorge's Avatar
Re: stock carb size
28 Nov 2005 06:35
#10625
VM26 w/accelerator pump... if you are trying to ID the carbs, look at the very bottom of the #2 carb bowl which contains the pump mechanism. It hangs down. The VM28 has NO cover over the very bottom where the VM26 will have a triangle shaped cover held on by three phillips head screws over the bottom. The 26 uses a two diaphragm pump where the 28 uses a single diaphragm... the 26 has a triangle shaped diaphragm over the bottom so the cover is needed but on the 28 it isn't.
